phischmi
(Philipp)
June 23, 2019, 8:32am
1
Hi all,
since updating to 0.95.0b1 i’m constantly getting a floating information about a discovered Google Cast, even though i ignored auto-discovery of google_cast in my configuration.
Anyone else facing this problem?
How can i solve it?
Regards
Philipp
I have the same problem. Also added the ignore line but hassio keeps find the Google cast.
I’m getting the exact same thing, very annoying, I assume it’s a bug, as 0.94.x didn’t do this.
I’ll set up an issue on GitHub if there’s not one already?
EDIT: There is one already, add your info in here if you haven’t done so already
https://github.com/home-assistant/home-assistant/issues/24786
h4nc
June 30, 2019, 6:56am
4
Same here. Started with 0.95
I’ve gone back to 0.94, it seems to be fixed on 0.94, so I can say that 0.95 caused this problem for me.
In the release notes for 0.95.0 here:
there is this:
Could this be causing the issues maybe?
Can I run 0.95 with the 0.94 pychromecast to test?
helgemor
(Helge)
July 29, 2019, 12:02pm
6
Same here. Started on 0.95. Now on 0.96.4.
Annoying, but not a good enough reason to go back to 0.94.
skynet01
(Alex)
August 29, 2019, 6:00am
7
Anyone figured out away to get rid of this? i have it marked to be ignored in discovery yet it still notifies me on bootup
what HA version are you running?
skynet01
(Alex)
August 29, 2019, 5:25pm
9
v0.98 but it was happening with 0.97 as well. But I think it started on 0.95 as well
Same here. Is there a way to ask for the documentation on “discovery” to be updated, at least?
skynet01
(Alex)
September 3, 2019, 5:36pm
11
Do you know what it should be to disable it?
I’ve unplugged my chromecast for now, short of putting on a VLAN and blocking it at a network level I don’t really see a solution for this.
skynet01
(Alex)
September 3, 2019, 6:05pm
13
You can just disable the Discover component. That makes it go away as well, but now new things won’t be discovered
Argo
(Argo)
October 2, 2019, 3:34am
14
How to disable discovery component?
skynet01
(Alex)
October 12, 2019, 9:37pm
15
comment out “discovery” in your config
