My raspberry pi is making every api call twice, 1x IPv4 and 1x IPv6
Is it possible to disable the IPv6 api calls?
I would also like to see why the api calls are duplicated when using IPv6. I would expect this is not expected behavior.
Hello!
some guys (including me) want to activate ipv6 here
how you got HASS listening on ipv6?
greetings
You can disable the ipv6 if running on a Pi as follows:
https://www.leowkahman.com/2016/03/19/disable-ipv6-raspberry-raspbian/
I think this should fix this. I’ve logged an issue again here https://github.com/home-assistant/home-assistant/issues/14068
