Disable Kodi Addon via API
I would like to create a script to disable the NextPVR Kodi addon via the JSON-RPC API. Based on the example in the Kodi integration docs and the API docs, I’ve put together this script but I get the error below on running the script.
Script:
service: kodi.call_method
  method: Addons.SetAddonEnabled
  addonid: pvr.nextpvr
  params:
    enabled: false
  entity_id: media_player.familyroom_kodi
HA Log Error:
Run API method media_player.familyroom_kodi.Addons.SetAddonEnabled({‘addonid’: ‘pvr.nextpvr’, ‘params’: {‘enabled’: False}}) error: {‘code’: -32602, ‘data’: {‘method’: ‘Addons.SetAddonEnabled’, ‘stack’: {‘message’: ‘Missing parameter’, ‘name’: ‘enabled’, ‘type’: [‘string’, ‘boolean’]}}, ‘message’: ‘Invalid params.’}
Here’s the relevant API documentation
Any help to troubleshoot would be appreciated.
You have to add both params (the addon name and the enabled flag) the same way. I used this to disable/enable the NextPVR addon from HA as a test, and it worked for me:
  enabled: false
  entity_id: media_player.vero4kplus
Sometimes, the answer is staring you right in the face and you don’t see it. Thanks so much for helping me out Kyle.
