I have a dumb ceiling light in my kitchen, which is controlled by a Shelly1. The normal light switch is directly coupled to the Shelly’s relays to have quick response. Operating the Shelly in ‘Detached Mode’ to toggle the light via an home assistant automation delays the actual response of the light compared to when the switch is pressen.
In addition to this, I have a Aquara Motion Sensor, which I use to turn on the light, but as this is not a presence sensor, it does sometimes fail and turns off the light, whilst someone is still in the kitchen (i.e. it is a great automation for when entering the kitchen to grab something, but it is poor for whenever someone is doing something in the kitchen, although my motion triggered automation already has a cool down period). … That said I should probably level up and get a Everything Presence 1
My thinking has been, that whenever the light switch is operated manually to turn on the kitchen light, the motion triggered light automation should be disabled until the light is manually switched off.
Motion Triggered Light Automation
- alias: Light - Motion in Kitchen
- platform: state
entity_id: binary_sensor.motion_kitchen
to: 'on'
#If motion is detected within the delay, the automation is restarted.
mode: restart
max_exceeded: silent
- choose:
- conditions:
#Turn kitchen light on automatically upon detected motion, in case ambient is dark
- condition: template
value_template: "{{ (states('sensor.lightlevel_kitchen') | int < states('input_number.illuminance_cut_off_kitchen') | int) }}"
sequence:
- service: light.turn_on
entity_id: light.kitchen
default: []
#Do not turn of the light in case kitchen appliances are running
- choose:
- conditions:
- condition: state
entity_id: device_tracker.thermomix
state: 'home'
sequence:
- wait_for_trigger:
platform: state
to: 'not_home'
default: []
- wait_for_trigger: #No more motion detected
platform: state
to: 'off'
#Wait a little longer before turning light back off
- delay: "{{ states('input_number.no_motion_wait_kitchen') | int }}"
- service: light.turn_off
Switch Triggered Automation
- alias: Light - Kitchen Light Automation Switch
platform: event
event_type: shelly.click
event_data:
device: shelly1-CAFEAFFEDEAF #Shelly 1 Küche
#Delay to consider light.kitchen may not be reported on immediatly upon button press
- delay: 2 #seconds
- if: #Light has just been turned on by the switch and now evaluates to 'on'
- condition: state
state: 'on'
then: #Disable motion light automation (i.e. light remains on until manually turned off.)
- service: automation.turn_off
entity_id: automation.light_motion_in_kitchen
else: #Automation is re-enabled, whenever the light is manually turned-off.
- service: automation.turn_on
However I struggle to get the logic right. The automation keeps enabling the automation, when I expect it to disable it and vice versa.
