Disable MQTT Entities dynamically
I have my windows shutters connected to Home Assistant through “MQTT Cover” integration. I also have a binary sensor telling me if my alarm is on. In this case I would like to disable the covers in order to avoid to accidentally open them through any automation or alexa routine. Is it possible to dynamically disable the covers or change the MQTT topic payload, based on the binary sensor value?
Thank you
Maybe use this Template Lock - Home Assistant to turn on/off the automations that may open the shutters.
Thank you, I will give a look.
