Is there any way to either remove the “Map” application from the left sidebar, or disable access to it for other users?
Press and hold ( 3 seconds )
Disable default_config: and replace it with all included components, except map:
(This is for advanced users only, done incorrect can make your HA stop from starting)
I already tried this technique.
Thanks but:
If you read the links I referenced. This approach only works for the current user web “session” and is NOT preserved across logins by the same user.
The left menu selections always re-appear after the user’s next login (makes no fundamental sense) that these selections/disblements are NOT preserved in the “Server” so as to remain in effect permanently.
There is certainly a way. I know this because I do not have the map in my sidebar. It does not come back with a new logon.
I just don’t remember how. I would bet dollars to donuts I found it with Google.
And, I know I didn’t disable the default config!
