With the newest version of ha core (0.107.x) a example below doesn’t work correctly any more. It shouldn’t show the header toggle, but as soon as two of lights are on, I get that header google although it should be hidden. This worked fine before.
Seems like a bug. Could some one test the example?
I have the same issue with the entity filter card - I can no longer get rid of the header toggle, and title: no longer displays a title.
(Unless we are both doing something stupid!)
This is working again after upgrading from 0.107.6 to 0.108.6. Had to clear cache but aftewards, the disable_header_toggle set to false works as expected.
EDIT: spoke too soon…
So it looks like something weird is going on. I’m using an entity filter for lights and have ~30 lights that are in scope for the card. After 3 or more lights are on, the header toggle shows up. But if there are <3 lights, the header toggle does not show up, which is the expected behavior.
