I’m probably in the minority in that I preferred the old Thermostat card (!). On the old card when my automation to ‘Boost’ my Hive heating fired, the Thermostat card clearly said ‘Boost’. This is no longer the case.
Also, is there a way to completely disable the slider? When scrolling controls on a phone it is extremely easy to change the temp by accident. Basically I am looking for the card to be a visual read-only representation of what’s going on with my heating because my heating is controlled via automations and I never need to adjust it manually.
I also agree that the slider is too easy to accidentally change. I think two things could make it better:
Require that you grab the “ball” of the slider to move it, instead of being able to click anywhere along the slider to instantly move it there. This probably solves 95% of the problem.
Enabling a lock feature which can be turned on (via the UI), where if you change the slider you get a popup confirmation box to accept, before the actual change is applied. Like Tap Action → Confirmation: Actions - Home Assistant This currently doesn’t seem to exist for the Thermostat card.
I agree too. I currently find the new thermostat card unusable on a phone when trying to scroll past it. Instead I use the tile card to display my climate entities until this gets fixed one day (hopefully).
I got this to semi work only because I just wanted a visual on my main dashboard where the voltage was, and the actual slider is on a hidden dashboard, which suits me perfectly.
So, basically, even though I included the user and passcode, it never unlocked for me (Possibly just too dense to figure it out ) but as I said, this worked to my advantage, as I did not really want to be able to change it from the visible dashboard anyway
Edit: Just added the “action: hold” function to the code (same indentation as the “round” function) and removed all the restrictions and users etc, and now it can be locked/unlocked, although, I reverted back to the original as it made more sense for my situation.
Just an update on this lock feature to maybe help someone out (Figured it out a while back but forgot there was a topic created for it), as it took me way longer to find the solution than I care to admit.
My final code I have that works very well on the dashboard side:
- type: custom:hui-entities-card
title: Battery Settings (Home Assistant)
entities:
- card:
entity: input_number.wattmeter_1_batt_volt_min
name: Voltage (Lower Limit)
row: true
type: custom:restriction-card
action: hold
restrictions:
confirm:
exemptions:
- user: Someone Else
pin:
text: Enter PIN to Unlock
code: 1234
max_retries: 3
max_retries_delay: 30
block:
exemptions:
text": User Interface Blocked
exemptions:
- user: Me
The only place I could find that you did not need the code to change the slider is obviously in the “Helpers” section and the raw code in the config file or where ever you put it.
Ps. Thanks to everyone that assisted in getting this working for me
