Disable SSID broadcast (AVM Fritzbox) via Home Assistant
Hi there,
I went through the entities, but I found no switch to toggle the SSID broadcast on/off.
Is there something?
Best Regards
Turning WiFi off should be possible with proper integration - it will also disables SSID broadcast! :mobile_phone_off:
Hi there,
okay, but what I want is to diasblae the SSID broadcast while the wifi is still on.
It is something which can be done manually (via FritzBox website), but the switch entity seems to be missing in home assitant.
BR
