Hi!
Is their any way to disable the touch on a map card?
When i scroll on my phone i want to be able to scroll even tough i scroll on the map card
Hi!
Try playing with css property āpointer-events: noneā for a corresponding element with card-mod.
Download the love-lock-card from hacks and set the map to timeout. Tap will unlock, then drag works. Saves a lot of miss-swiping.
type: custom:love-lock-card
popup: timeout
cards:
- type: map
entities:
- entity: device_tracker.1
- entity: device_tracker.2
hours_to_show: 24
theme_mode: auto
Iām late to the game on this, but for anyone that tries the lock-card approach mentioned above, it worked for me. HOWEVER, I was required to add another map to the same page and then update the visibility so that it didnāt show for any HA user. For some reason, unless this other map was hidden all the time, the initial map I wanted to lock would occasionally throw a yaml error.
