Disable / Unload package in packages
I would like a way to disable or unload a package in your packages folder.
Maybe manually by renaming the packages file from
xxxxx.yaml to
_xxxxx.yaml
or if all your packages was listed under configuration and you there could “check” or “uncheck” a box to enable/disable the package and then restart home-assistant.
I know i can move the package file out from the packages folder to disable it, but it would be nice to be able to keep them there.
I tend to rename stuff from .yaml to .yaml.bak to disable things.
With packages you’ll have to restart HA (I think) to reload and get those disabled.
Is there a way to disable a whole package folder?
I have multiple subfolders inside the main packages folder, and i want to disable a single folder of them.
