Disabled Lan Interface by mistake, any way back?
Hii,
it looks like I disabled LAN interface on my HA using the supervisor UI, i can not reach out to HA ip not pinging, any way to get access back to it ??
I’m using HASS OS on RPI4
What did you do to disable it in the UI?
You can recover it by connecting a monitor and keyboard the the pi and using nmcli commands (search the forum) to set the network again.
thanks Tom, will i need to authenticate to login ? should i user my hass credentials ?
