Hi all,
I’m running in Docker and forwarding logs elsewhere. Is there any way to disable ANSI escape sequences, as I end up with logs like:
e[32m2017-11-22 16:16:20 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initializede[0m
(note escape sequences at beginning and end)
I’ve tried changing TERM
to something like xterm-mono
, but it appears to be disregarded. The problem is essentially the same as this from the moby project.
Thanks!
