Hi there,
I’ve recently purchased a switch (thankfully only the one at this stage), thinking it was the following:
The device has paired fine via Zigbee2MQTT, but it appears I’ve actually purchased the following:
This is super frustrating as the difference between the two appears to be power off behaviour and backlight - the two reasons I elected to try the switch.
I am hoping that someone may be aware of a workaround to disable the backlights. The switch is intended for use in bedroom; I will not get the thumbs up from the other half if there is a light coming from our switches overnight.
Cheers!
