Disabling ESPHome device based on HA Input Boolean
I’m trying to prevent an ESPHome device, from taking actions, based on the state of an input boolean within home assistant.
So if the input boolean is off then stop the cover on a esphome device from opening/closing. If the boolean is on then allow the cover to operate normally.
I keep rolling my face on the keyboard and it’s not working. Any help would appreciated.
Whether or not the pool is open for the summer
input_boolean.pool_open
esphome device for controlling the pool cover:
switch:
  - platform: gpio
    pin: GPIO16
    internal: true
    interlock: [relay_2]
  - platform: gpio
    pin: GPIO17
    internal: true
    interlock: [relay_1]
cover:
    open_action:
      - switch.turn_on: relay_1
      - delay: 1000ms
      - switch.turn_off: relay_1
      - delay: 1000ms
      - delay: 24000ms
      - cover.template.publish:
          state: OPEN
    close_action:
      - switch.turn_on: relay_2
      - delay: 1000ms
      - switch.turn_off: relay_2
      - delay: 1000ms
      - delay: 33000ms
          state: CLOSED
Right, but how do I disable the cover entity in esphome - not take actions based on the sensor.
You add an if to your cover’s action sequences, so it doesn’t do anything unless the desired conditions are met.
And I would not make it based on a HA sensor but add a switch for it in the ESP. Something like:
switch:
  - platform: gpio
    pin: GPIO16
    internal: true
  - platform: gpio
    pin: GPIO17
    internal: true
    optimistic: true
    restore_mode: RESTORE_DEFAULT_OFF
cover:
    open_action:
      - if:
          condition:
             - switch.is_off: cover_lock
          then:
            - delay: 1000ms
            - delay: 1000ms
            - delay: 24000ms
                state: OPEN
    close_action:
      - if:
          condition:
          then:
            - delay: 1000ms
            - delay: 1000ms
            - delay: 33000ms
                state: CLOSED
Ahhh, I was misunderstanding the docs, didn’t grok that the if could be on any component. Thank you
Thanks septillion <3
