I am sorry if this has been answered previously.
I am trying to disable the Philips Hue integration in Home Assistant.
I have tried the following lines in configuration.yaml
discovery:
ignore:
- philips_hue
But I am still observing that the Philips Hue Integration causing my devices to not register with Alexa.
How can I remove or completely disable the integration?
Thanks in advance.
Update: Observing following error message in the logs even after ignoring the Philips Hue Integration
2021-10-27 15:26:30 ERROR (MainThread) [homeassistant.components.hue] Unknown error connecting with Hue bridge at [redacted IP address for Hue device]
File "/usr/src/homeassistant/homeassistant/components/hue/config_flow.py", line 146, in async_step_link
await authenticate_bridge(self.hass, bridge)
File "/usr/src/homeassistant/homeassistant/components/hue/bridge.py", line 292, in authenticate_bridge
await bridge.initialize()
File "/usr/local/lib/python3.9/site-packages/aiohue/bridge.py", line 70, in initialize
self.config = Config(result.pop("config"), self.request)
TypeError: 'str' object cannot be interpreted as an integer
