Disapearing entities Fibaro fgd212 dimmer
Hello Hass,
I have a problem in Hass with my Fibaro dimmer fgd212, one of the entities of the dimmer is not always showing up. For example the dimmer have two entities:
  • light.fibaro_system_fgd212_dimmer_2_level
  • light.fibaro_system_fgd212_dimmer_2_level_2
Only one of them is visible right now, so my automation isn’t working as well.
This happens also sometimes with my Aeotec multisensor, I own two identical sensors.
Can anybody tell me what I can do to change that?
Thnx in advance,
André
I’ve just started experiencing the same with my 2 fibaro fgd212 dimmers, started happening after I recently upgraded to 0.62.1. It appears to be random on restart, one of the two usually works but you never know which. Then sometimes they both work. Hope someone knows the answer to this!
Yes it starts after the upgrade, the same phenomenon here. So I think it is a bug.
Looks like an issue in .62, may be fixed for .63 according to this thread on github. https://github.com/home-assistant/home-assistant/issues/11997
Thank you for informing me, we need to wait patiently :slight_smile:
everything is fixed, thnx
