does anybody got an idea what it actually writes to the disc at 2% a day rate ?
Due to additional load it obviously gives 8degC to the processor, but that is just coolig, disc space is a real issue…
I’ve started my HA (running 1,5 years now) on a 32GB NOOBS RPI4 and it seems not easy at all to switch to bigger one. Anyway eventually it would fill any space so changing cards doesn’t make sense.
Thanks.
TTS may save files in a tts folder in your config share. So the space may have nothing to do with Node Red per se, just that when it doesn’t run TTS also isn’t used. AFAIK it is just a cache and you can safely delete those files.
