Disco Light help
My quick solution goes like this with just copying the actions and focus on the basic colors. Lokks nice :slight_smile:
repeat:
  while:
    - condition: state
      entity_id: input_boolean.party
      state: "on"
  sequence:
    - service: light.turn_on
      data_template:
        entity_id: light.shellyrgbw2_e868e7f34e2a
        rgbw_color:
          - "255"
          - "{{ (range(0, 100)|random) }}"
          - "0"
        brightness: "{{ (range(50, 250)|random) }}"
        transition: 0.1
    - delay: "{{ states.input_number.party_speed.state }}"
      data_template:
        rgbw_color:
          - "255"
          - "0"
        transition: 0.2
      data_template:
        rgbw_color:
          - "255"
          - "0"
        transition: 0.2
Thanks all for this info. I managed to setup three bulbs running separate scripts.
What would be nice if we could setup this as a blue print so this could be setup eaiser. Would also be great if we could setup a list of light colours to choose by name.
Any ideas how this could be done as a blueprint?
Thanks for awesome sharing in this post!
I’m not completely finished with the tuning, but this example shows how we can create a list of explicit RGB colors to choose from (which could be extended for easier use). The only thing I’d like to do is modify the random selector to calculate the length of the color array rather than explicitly set a range.
lights_partying:
  variables:
    colors:
      - [25,25,112]
      - [72,61,139]
      - [255,0,0]
      - [255,140,0]
  sequence:
    - repeat:
        while:
          - condition: state
            state: "on"
        sequence:
            data_template:
              entity_id: group.downstairs_living_room
              rgb_color: "{{ colors[(range(0, 3)|random)] }}"
              transition: 0.1
Have you figured this out yet?
I’m struggling with the same thing.
Thanks all for the code.
I’ve used the repeat - while and the code within there, with some minor adjustments for the lights/LEDs I want to use this code on, but I’ve found that it stops on a random color after 3 to 5 colors.
Turn it on, lights come on with a random color, the change as per the setting, but after 3 to 4 color changes, it just stops changing and stays on the final color.
I don’t suppose anyone knows what I’m doing wrong?
Once I turn the Boolean off, it follows the correct automation sequence and does what its supposed to, but I just can’t get it to keep changing color.
For me, the following worked, only replace the entity_id: light.living_room_lights with yours in scenes.yaml, automation.yaml and in scripts.yaml:
In scenes.yaml:
- id: '1697057636536'
  entities:
    light.living_room_lights:
      state: 'off'
  metadata: {}
In configuration.yaml:
input_boolean:
  party:
    icon: mdi:party-popper
    initial: off
input_number:
  party_speed:
    initial: 0.4
    min: 0.1
    max: 0.9
    step: 0.1
switch:
    switches:
      party:
        value_template: '{{ states("input_boolean.party") }}'
        friendly_name: "La Festa"
        turn_on:
        turn_off:
          - service: input_boolean.turn_off
In automations.yaml:
- alias: "Lights partying on"
  id: "La Festa ON"
  initial_state: true
    - platform: state
      to: "on"
    service: script.lights_partying_on
- alias: "Lights partying off"
  id: "La Festa OFF"
  initial_state: true
    - platform: state
      to: "off"
    - service: light.turn_off
      entity_id:
        - light.living_room_lights
    - delay: 1
    - service: script.lights_partying_off
In scripts.yaml:
lights_partying_on:
  alias: Lights partying on
  sequence:
    - service: scene.create
        scene_id: party
        snapshot_entities:
    - service: script.turn_on
      entity_id: script.lights_partying
lights_partying:
  sequence:
    - repeat:
        while:
          - condition: state
            state: "on"
        sequence:
            data_template:
              rgb_color:
                  "{{ (range(0, 255)|random) }}",
              transition: 0.1
lights_partying_off:
  alias: Lights partying off
  sequence:
    - service: scene.turn_on
        entity_id: scene.party
