cozilic
(Patrik Forsberg)
December 28, 2020, 11:51am
1
I am a real beginner on hassio, but i want to have a light that changes color fast (like a disco) in my dahugters room, i have the basic setup for it, but i can’t get it to loop… this is what i currently have in scripts:
lights_party_on:
alias: Party ON!
sequence:
service: light.turn_on
data_template:
entity_id: light.lampa_emmas_rum_2
rgb_color:
"{{ (range(0, 255)|random) }}",
brightness: "{{ (range(50, 250)|random) }}"
transition: "0.1"
But i want it to loop, and if possile have a slider that i can change the speed of it
Thanks in advance
/Cozilic
cozilic
(Patrik Forsberg)
December 28, 2020, 12:10pm
2
ok, i got it to work… with some modifications from another script… now i just need a slider to controll the speed…
cozilic
(Patrik Forsberg)
January 4, 2021, 1:40pm
3
I’ve manage to get a slider to for somwhat good, put want it on the ui and not on a buttonpress… I’ll check some more
Could you please share your configuration?
I’m also very interested in your setup if you don’t mind sharing it!
cozilic
(Patrik Forsberg)
February 6, 2021, 8:13am
6
Here is my configuration for my party lights setup, based on another script here.
configuration.yml
# # Inputs
input_boolean:
party:
icon: mdi:party-popper
initial: off
input_number:
party_speed:
initial: 0.4
min: 0.1
max: 0.9
step: 0.1
# # Switch
switch:
switches:
party:
value_template: '{{ states("input_boolean.party") }}'
friendly_name: "La Festa"
turn_on:
entity_id: input_boolean.party
turn_off:
- service: input_boolean.turn_off
automation.yaml
- alias: "Lights partying on"
id: "La Festa ON"
initial_state: true
- platform: state
to: "on"
service: script.lights_partying_on
- alias: "Lights partying off"
id: "La Festa OFF"
initial_state: true
- platform: state
to: "off"
- service: light.turn_off
entity_id:
- light.lampa_emmas_rum_2
- delay: 1
- service: script.lights_partying_off
inputs.yaml
party:
icon: mdi:PartyPopper
initial: off
switch:
switches:
party:
friendly_name: "Party!"
turn_on:
turn_off:
scripts.yaml
lights_partying_on:
alias: Lights partying on
sequence:
- service: scene.create
scene_id: studioprimaparty
snapshot_entities:
- service: script.turn_on
entity_id: script.lights_partying
lights_partying:
sequence:
- repeat:
while:
- condition: state
state: "on"
sequence:
- service: light.turn_on
data_template:
rgb_color:
transition: 0.1
- delay: "{{ states.input_number.party_speed.state }}"
lights_partying_off:
alias: Lights partying off
sequence:
- service: scene.turn_on
entity_id: scene.studioprimaparty
Looks like this:
Hi, I have tride to use your code and just change light.lampa_emmas_rum_2
to the name as my light is. But I dont get it to work.
How do you “link” to “inputs.yaml”
I dont get input: !include inputs.yaml
to work. or inputs: !include inputs.yaml
Thanks. =)
Thanks for that @cozilic
Any idea on how to add extra lights? Also is there a way to smooth the transitions?
cozilic
(Patrik Forsberg)
April 27, 2021, 10:36am
10
I’ll check how to add more lights, but I think the transition is: transition: 0.1 under Scripts.yaml
cozilic
(Patrik Forsberg)
11
I’ll check how I added the input.yaml file
but tbh I think from another version of your script I found lol
But also I would love to see your updated script
cozilic
(Patrik Forsberg)
April 27, 2021, 10:57am
15
It’s not my script, I found a script that I modified for my needs, I take no credit for this script at all
Roumano
(Roumano)
November 15, 2021, 5:21pm
18
Thanks for this !
Instead of two icons, it’s better to use custom:slider-entity-row
to change the speed, it’s take less space and can be change with only one clic !
- type: vertical-stack
cards:
- type: button
tap_action:
action: toggle
entity: switch.party
- entity: input_number.party_speed
type: custom:slider-entity-row
full_row: true
Can you elaborate on how you got it working?
Can someone explain what to do with the inputs.yaml bit and how to actually get a card in Lovelace to control the whole thing? I do not see any inputs.yaml file in my homeassistant installation. I tried creating a new file at the same level as configuration.yaml but that still did not seem to do anything.
I got it working
Ignore the inputs.yaml
file above, and make a card on your lovelace dashboard as @Roumano said with:
cards:
- type: button
tap_action:
action: toggle
full_row: true
This assumes you have GitHub - thomasloven/lovelace-slider-entity-row: 🔹 Add sliders to entity cards installed
dr-insane
(Jan Hupfeld)
February 17, 2023, 7:53am
22
Thanks a lot for the dicussion. Finally i´ve got it running with my shelly rgbw2.
Since white type of colors ofte show up, I am wondering if it would be possible to add a color list, where the script randomly picks the colors.
I suppose the colors should be also defined in the lights partying script.
data_template:
entity_id: light.shellyrgbw2_e868e7f34e2a
rgbw_color:
- "{{ (range(0, 255)|random) }}"
- "0"
transition: 0.2
Would be something like this:?
- alias: "Set variables"
variables:
entities:
- rgbw_color1
rgbw_color: 0,200,0,0
- rgbw_color1
rgbw_color: 200,0,0,0
Anybody who could help?
