Disconnecting CC2531 from RPi
Hi, i have just connected my CC2531 to my HA running in RPi and i have setup everything including MQTT, zigbee2mqtt as well as connected few Xiaomi devices. Everything is working fine and now i would like to install a 3D printed case to my CC2531.
To remove the CC2531 from my RPi, i presume i have to stop the zigbee2mqtt add-on first, then un-plug the CC2531, put on the casing, re-insert the stick to RPi and start the zigbee2mqtt addon. Are the steps correct? Do i have to shutdown/restart my HA? Any other precaution i need to take note before removing the CC2531 stick?
Thanks in advance.
Not strictly necessary to shutdown HA, but it is always better
