Hello everyone,
I hope you’re all doing well!
I’m reaching out because I’m experiencing some recurring disconnection issues with my IKEA Matter over Thread devices in Home Assistant. I’m struggling to figure out whether the issue is related to Matter, Thread, or something else entirely.
Background
To give you some context (sorry, this might be a bit of a long post), I originally had some Wi-Fi light bulbs and smart plugs from Action (yes, I know, everyone has to start somewhere lol), along with some Zigbee sensors and a Zigbee smart plug. Everything was integrated into HA using the LocalTuya add-on for compatible devices, and it all worked pretty well. I controlled everything using Alexa speakers, with a bit of tinkering here and there.
I then decided to upgrade my smart home setup by moving away from Wi-Fi and switching to Thread and Zigbee. Since I was also replacing my Echo speakers with HomePods, Matter over Thread seemed like the natural choice.
I therefore purchased some IKEA KAJPLATS light bulbs (Thread), GRILLPLATS smart plugs (also Thread), and TIMMERFLOTTE temperature sensors. My HomePods are Matter-compatible and also act as Thread Border Routers, as does my Apple TV. I currently have 8 HomePods and 1 Apple TV (connected via Ethernet) acting as Thread Border Routers.
Everything initially worked perfectly, both through Siri and Home Assistant.
One important detail: I first pair my bulbs, sensors and smart plugs with Apple Home, and then add them to Home Assistant. I had read somewhere that Apple Home didn’t handle being added as a secondary controller particularly well, so I decided to follow this approach.
So far, so good. I then decided to purchase some IKEA BILLRESEA remotes, which are also compatible with Matter over Thread. Unlike my other devices, these are paired directly with HA and do not appear in Apple Home. I created automations to turn lights on and off, adjust brightness, etc.
The problem
Things started going downhill when I needed to replace my Zigbee coordinator. I switched to an SMLIGHT MR1U, which has two antennas, one of which is dedicated to Wi-Fi.
I thought that while I was at it, I might as well add this device to my Thread network too. So I configured the SMLIGHT in “Thread to remote OTBR” mode, installed OTBR on HA, and successfully added it to my existing Thread network.
That’s when the problems started. Every now and then, I would press a button on one of my BILLRESEA remotes and nothing would happen. Sometimes, the action would eventually be executed, but up to five minutes later.
I also started experiencing issues with my temperature sensors, which would stop reporting their readings and show up as “Unavailable” in HA. The same thing happened with the BILLRESEA remotes.
Meanwhile, everything continued to work perfectly in Apple Home.
Initially, simply removing the batteries from the affected devices and putting them back in was enough to get everything working again.
However, around 2 or 3 weeks ago, the disconnections became a daily occurrence. This time, even my light bulbs started showing up as “Unavailable” in HA, while continuing to work perfectly fine in Apple Home.
I really can’t figure out what’s causing this.
I’ve tried reinstalling HA and, this time, completely removed the SMLIGHT from my Thread network. I also factory-reset and re-paired my bulbs and other devices with HA.
Unfortunately, nothing has helped. I’m still experiencing random disconnections, even though everything continues to work flawlessly in Apple Home.
At this point, I’m a bit lost and haven’t been able to identify the root cause of the problem.
Has anyone experienced something similar or have any suggestions on how I could troubleshoot this and identify what’s going wrong?
Thanks in advance for your help!
My HA Configuration
[center]
System Information
| version | core-2026.11.1 |
| installation_type | Home Assistant OS |
| dev | false |
| hassio | true |
| docker | true |
| container_arch | amd64 |
| user | root |
| virtualenv | false |
| python_version | 3.14.10 |
| os_name | Linux |
| os_version | 6.18.58-haos |
| arch | x86_64 |
| timezone | Europe/Paris |
| config_dir | /config |
Home Assistant Supervisor
| host_os | Home Assistant OS 18.4 |
| update_channel | stable |
| supervisor_version | supervisor-2026.11.0 |
| agent_version | 1.14.0 |
| docker_version | 29.8.2 |
| disk_total | 30.8 GB |
| disk_used | 13.5 GB |
| nameservers | 94.140.14.140, 192.168.43.15, 149.112.112.112, 94.140.14.141, 9.9.9.9 |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | kvm |
| board | ova |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Matter Server (9.3.0), Studio Code Server (7.2.0), Music Assistant (2.10.9), go2rtc (1.9.15), Terminal & SSH (10.6.0), room-assistant (2.20.0), Zigbee2MQTT (2.14.3-1) |
Dashboards
| dashboards | 6 |
| resources | 8 |
| views | 4 |
| mode | storage |
Marketplace
| download_profile | default |
| github_api | ok |
| github_content | ok |
| github_web | ok |
| catalog_data | ok |
| github_connected | true |
| installed_version | 2026.11.1 |
| stage | running |
| available_repositories | 6738 |
| installed_repositories | 7 |
| github_api_calls_remaining | 5000 |
Network Configuration
| adapters | lo (disabled), enp6s18 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth886847b (disabled), veth3a48895 (disabled), veth319a16f (disabled), veth069ff0d (disabled), veth9910996 (disabled), veth25f594b (disabled), veth149c64f (disabled), veth061dd29 (disabled), vethba13b42 (disabled) |
| ipv4_addresses | lo (127.0.0.1/8), enp6s18 (192.168.43.251/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth886847b (), veth3a48895 (), veth319a16f (), veth069ff0d (), veth9910996 (), veth25f594b (), veth149c64f (), veth061dd29 (), vethba13b42 () |
| ipv6_addresses | lo (::1/128), enp6s18 (fd7c:2c33:b2a9:4ea9:a194:3e38:b5c6:2de4/64, fe80::cfc:2a3:b8b0:4ef8/64), docker0 (fdf5:51e6:69c2::1/64, fe80::b80c:63ff:fe95:a550/64), hassio (fd0c:ac1e:2100::1/48, fe80::2c88:dbff:fe8a:2ec8/64), veth886847b (fe80::982b:dbff:fe9c:a9c1/64), veth3a48895 (fe80::181f:3aff:fe97:cd37/64), veth319a16f (fe80::b072:10ff:fedb:1ff4/64), veth069ff0d (fe80::5430:10ff:fec3:b52f/64), veth9910996 (fe80::30b2:bfff:fee9:6b73/64), veth25f594b (fe80::8cdb:35ff:fe19:3d99/64), veth149c64f (fe80::28da:c5ff:fef9:47cc/64), veth061dd29 (fe80::f85e:24ff:fe58:ca24/64), vethba13b42 (fe80::a0a9:77ff:fe5d:aed6/64) |
| announce_addresses | 192.168.43.251, fd7c:2c33:b2a9:4ea9:a194:3e38:b5c6:2de4, fe80::cfc:2a3:b8b0:4ef8 |
Recorder
| oldest_recorder_run | November 5, 2026 at 11:23 PM |
| current_recorder_run | November 18, 2026 at 12:47 AM |
| estimated_db_size | 457.55 MiB |
| database_engine | sqlite |
| database_version | 3.53.4 |
