I have been using Discord as notification platform for some time now.
Messages all similarly formatted:
Recently, I noticed that i don’t get messages anymore.
Checking logs I found below error:
Logger: homeassistant.core
Source: components/discord/notify.py:70
First occurred: 3:55:14 PM (1 occurrences)
Last logged: 3:55:14 PM
Error executing service: <ServiceCall notify.discord (c:706c4a0fbcad6156d529c24754db2b2b): message=Template(""), data=embed=title=Window Open, description=Bedroom Window 1 still open, url=https://www.home-assistant.io, color=199363, author=name=Home Assistant, url=https://www.home-assistant.io, icon_url=https://www.home-assistant.io/images/favicon-192x192-full.png, footer=text=payload &" | Window & Door Alerts", thumbnail=url=https://www.home-assistant.io/images/favicon-192x192-full.png, fields=[{'name': 'Sensor: Open/Close', 'value': 'Open', 'inline': True}, {'name': 'Light Intensity', 'value': '$entities("sensor.lightlevel_7").state', 'inline': True}], target=['812330990734934038']>
File "/usr/src/homeassistant/homeassistant/core.py", line 1654, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1673, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 222, in _async_notify_message_service
await self.async_send_message(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/discord/notify.py", line 70, in async_send_message
embed = nextcord.Embed(**embedding)
TypeError: __init__() got an unexpected keyword argument 'author'
It seems that the message format i used is no longer handled the same way.
These are Discord embeds. The guide to them is still showing the same configuration.
Simpler messages get sent, so it is not total notification failure, it’s the message format.
Did I miss some change in message formatting?
Is it a bug I should report at github?
Oh, message format I use:
{ "message":"",
"data":{
"embed":{
"title":"Window Open",
"description":"Bedroom Window 2 still open",
"url":"https://www.home-assistant.io",
"color":199363,
"author":{
"name":"Home Assistant",
"icon_url":"https://www.home-assistant.io/images/favicon-192x192-full.png"
"footer":{"text":payload &" | Window & Door Alerts"},
"thumbnail":{
"url":"https://www.home-assistant.io/images/favicon-192x192-full.png"
"fields":[
"name":"Sensor: Open/Close",
"value":"Open",
"inline":true
"name":"Light Intensity",
"value": $entities("sensor.lightlevel_7").state,
"inline":true
Any help is appreciated.
Cheers, Peter
