Discovered MQTT devices stopped working
For the past few months I’ve had some sensors in my garden feeding sensor information to HA using MQTT. It’s been working fine and then about a week ago I found this in the UI
I haven’t been able to get it working again. The logs show that HA is receiving the information
2019-07-12 19:14:21 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/fence/state: b'{"moisture": 30, "light": 4280, "battery": 76, "temperature": 18.5, "conductivity": 193}'
2019-07-12 19:15:38 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/trug1/state: b'{"moisture": 39, "light": 1142, "battery": 61, "temperature": 18.3, "conductivity": 246}'
2019-07-12 19:15:58 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/fence/state: b'{"moisture": 31, "light": 3993, "battery": 76, "temperature": 18.2, "conductivity": 194}'
2019-07-12 19:17:03 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/trug1/state: b'{"moisture": 39, "light": 1001, "battery": 61, "temperature": 18.3, "conductivity": 241}'
2019-07-12 19:17:59 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/sensor/fence/state: b'{"moisture": 30, "light": 3700, "battery": 76, "temperature": 17.6, "conductivity": 196}'
But for want of a better description HA has suddenly decided it’s going to ignore it and I can’t figure out why. MQTT config is straightforward (and unchanged)
mqtt:
  broker: 192.168.1.200
  client_id: homeassistant
  discovery: true
  discovery_prefix: homeassistant
Can anyone suggest what else I can check? There were no configuration changes around the time this happened. The only errors in the log are rate limit errors for things I should get round to throttling and the occasional 404 from NetAtmo requests. Other than that everything is working as expected except this.
Steve
Check to see if they show up in the MQTT integration in the configuration menu.
Maybe something out of the box.
Did you gave the sensor a static IP in your router? Faced that problem before aswell
Some of them are bluetooth devices so they don’t have IP addresses - they use this: miflora-mqtt-daemon
The other devices are a mixture of Arduino and NodeMC devices which do have IP addresses but they’re able to publish to the MQTT server which is a VM. It’s definitely not a communication problem.
There are other publishers (e.g. Owntracks) publishing to MQTT but not using discovery. These are working fine in HA.
There’s nothing there. As I said, HA sees the message in the homeassistant/+/+ queue, reads it and then does nothing with it. If the line wasn’t appearing in the logs then the problem would be elsewhere but HA is reading the message from the queue and failing to process it. It’s not complaining, for example, about the format of the payload - it just seems to discard the message.
What about activating the debug mode for it. See if you can get some information about it. “debug info”
Check the dev states menu then the <> button they may have changed names for some reason and/or check the Entity Registry
Debugging doesn’t give me any other information. If I subscribe to the topic I can see the message - a correctly formed and valid topic with payload - arrive without a problem
$ mosquitto_sub -h 127.0.0.1 -v -t "homeassistant/#"
homeassistant/sensor/trug1/state {"moisture": 33, "light": 308, "battery": 61, "temperature": 17.7, "conductivity": 180}
The problem appears to be that HA no longer “converts” sensor/trug1/state {“light”:200} to sensor.trug1_light - in fact it doesn’t convert it to anything. But there’s no error saying it’s a malformed payload or there’s an error with sensor.trug1_light - it just doesn’t do anything.
