I just updated my Home Assistant and after that I am unable to get my MQTT devices to work
Home Assistant 2023.9.2
Supervisor 2023.09.2
Earlier I had my MQTT devices in configuration.yaml but after the update it gave me error to remove them from the configuration.yaml and use GUI to add these devices.
mqtt:
broker: core-mosquitto
username: !secret mqtt_username
password: !secret mqtt_password
- name: "Gyeser"
state_topic: "tele/gyeser/SENSOR"
value_template: '{{ value_json["ENERGY"]["Today"] }}'
unit_of_measurement: "kWh"
light:
- name: "Upper Living Right"
state_topic: "stat/ulivingr/POWER"
command_topic: "cmnd/ulivingr/POWER"
availability_topic: "tele/ulivingr/LWT"
optimistic: false
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: true
So I have commented above code in configuration.yaml
Devices are Sonoff devices flashed with Tasmota. After commenting these lines in configuration.yaml the error is gone but the devices aren’t there anymore and I am not sure how to rediscover them via GUI now. I went to “Settings->Devices & Services->Integration” but I don’t see any new devices popup. There is no option to add them via MQTT or Tasmota integration button available there.
Would be grateful if someone could kindly guide on how to discover these devices now. Thank you.
