I have the same problem
Use esphomeyaml with mqtt discovery for some nodemcu with the latest version from esphomeyaml.
And after upgrade of HASS to version 0.87 i got this in the log for all “lights”
@OttoWinter any idea ?
2019-02-07 14:34:14 WARNING (MainThread) [homeassistant.components.mqtt.discovery] "platform": "mqtt_json" is deprecated, replace with "schema":"json"
2019-02-07 14:34:14 ERROR (MainThread) [homeassistant.components.mqtt.light] Exception in async_discover when dispatching 'mqtt_discovery_new_light_mqtt': ({'flash': True, 'name': 'light_dckw2cjwud', 'platform': 'mqtt', 'state_topic': 'control_3dprinter/light/light_dckw2cjwud/state', 'command_topic': 'control_3dprinter/light/light_dckw2cjwud/command', 'availability_topic': 'control_3dprinter/status', 'unique_id': 'ESPlightlight_dckw2cjwud', 'device': {'identifiers': '5ccf7f033ea5', 'name': 'control_3dprinter', 'sw_version': 'esphomelib v1.10.1 Feb 7 2019, 14:32:35', 'model': 'PLATFORMIO_NODEMCUV2', 'manufacturer': 'espressif'}, 'schema': 'json'},)
File "/usr/src/app/homeassistant/components/mqtt/light/__init__.py", line 60, in async_discover
config = PLATFORM_SCHEMA(discovery_payload)
File "/usr/local/lib/python3.6/site-packages/voluptuous/validators.py", line 207, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.6/site-packages/voluptuous/validators.py", line 286, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.6/site-packages/voluptuous/validators.py", line 282, in _exec
v = func(v)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 811, in validate_callable
return schema(data)
File "/usr/src/app/homeassistant/components/mqtt/light/__init__.py", line 36, in validate_mqtt_light
return schemas[value[CONF_SCHEMA]](value)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.6/site-packages/voluptuous/schema_builder.py", line 427, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: extra keys not allowed @ data['flash']
