Discovery does not work
I have Home Assistant installed on a Synology 214play (NO Docker!) for some reason it seemes that there was already a user homeassistant on my Syno, but i can not find it on my syno. So i tried to make a new user assistant, change hass-daemon user to assistant changed chmod -R to 777 otherwise you cannot edit and save configs in /homeassistant. Too bad this dit not work so changed to default homeassistant in hass-daemon, now i can start HA with ipadres:8123 but discovery does not work. Only sun and yr symbol. i also have Apple TV 4 zwave and Philips hue 2 bridge but it wil not be found.
part of configuration.yaml
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
