I am using zigbee2mqtt and Mosquitto broker in hassio (HassOS 3.13) and I am having an issue with zigbee devices, because every time I remove one device from Home Assistant and add it again, Home Assistant doesn’t create an entry in the Entities or Devices list for the device.
I am removing the device using topic zigbee2mqtt/bridge/config/force_remove, and then when I add the device again, zigbee2mqtt recognise it (I can see the message {"type":"pairing","message":"interview_successful","meta":{"friendly_name":"xxxxxxxxxxxx","model":"xxxxxxxx","vendor":"xxxxxx","description":"xxxxxxxxx","supported":true}}
and any other subsequent message sent by the device in the zigbee2mqtt log, so pairing is successful), but Home Assistant doesn’t create an entry in the Entities or Devices list for the device.
I already checked the option “Enable newly added entities” is enable within MQTT system options, so I don’t understand why the device is not added to the devices/entities list, is anyone having the same issue? is there any log where I can see why MQTT is not adding the device properly?
