I’m trying to set up my new Philips Hue hub, but the page at /config/integrations hangs every time. I’ve commented out everything in my configuration.yaml except the following:
homeassistant:
# Location required to calculate the time the sun rises and sets
latitude: 111
longitude: 222
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 00
unit_system: imperial
time_zone: America/Chicago
whitelist_external_dirs:
- '/tmp'
frontend:
http:
# Uncomment this to add a password (recommended!)
api_password: !secret http_password
server_port: 80
# Discover some devices automatically
discovery:
I get a box that says “New Devices Discovered, We have discovered new devices on your network. Check it out.” When I click on “Check it out”, it takes me to /config/integrations, and it just hangs. This is all I get in the logs:
2018-11-25 20:20:14 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-11-25 20:20:21 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-11-25 20:20:34 WARNING (SyncWorker_6) [netdisco.ssdp] Found malformed XML at http://192.168.1.89:9080: status=ok
2018-11-25 20:20:39 WARNING (MainThread) [homeassistant.components.hue] Connected to Hue at 192.168.1.151 but not registered.
2018-11-25 20:20:42 ERROR (SyncWorker_7) [pywemo.ssdp] Found malformed XML at http://192.168.1.89:9080: status=ok
2018-11-25 20:20:49 WARNING (MainThread) [homeassistant.setup] Setup of wemo is taking over 10 seconds.
2018-11-25 20:21:11 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-11-25 20:21:40 WARNING (Thread-2) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-11-25 20:21:40 WARNING (Thread-3) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-11-25 20:21:40 WARNING (Thread-5) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-11-25 20:21:40 WARNING (Thread-4) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2018-11-25 20:22:08 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
How can I get the integrations page to work? What am I missing
Thanks in advance!
