Discovery: Network is unreachable (0.86 and up)
Starting with 0.86 and also 0.87, my logging is spawned every 5 minutes with the following message:
2019-02-08 14:25:34 ERROR (MainThread) [homeassistant.components.discovery] Network is unreachable
2019-02-08 14:30:35 ERROR (MainThread) [homeassistant.components.discovery] Network is unreachable
2019-02-08 14:35:36 ERROR (MainThread) [homeassistant.components.discovery] Network is unreachable
I am running in docker and “–net=host” … That worked in previous versions perfectly. Anybody an idea what i get this?
Not sure, but I also just started getting this. Also running docker with the container in host networking mode
I should clarify, I only receive this error once when I restart HASS. Also, I can’t seem to discover my cast devices (not sure if related, but it seems to be)
I can confirm I have the same issue
Confirming I have the same issues. Log is flooded with that message every 5 minutes and I can no longer find my Google Cast devices. There are no network security settings set up to block access between the two and this started occurring in 0.86.
Error:
components/discovery.py (ERROR)
I change the Python code a bit, and i see the following error in the logging (OSError):
‘[Errno 105] No buffer space available’
I have seen this before, but not continuesly.
I typed the following command:
sysctl net.ipv4.igmp_max_memberships=40
And restart HASS … This solves it, because the max membership is by default 20.
Have had the same issue for quite some time. That command that you mentioned, did you run it in the HASS container or on the host OS?
I tried it on both and neither worked.
EDIT2: Bumped it to 80 and it seems to be working now. Hoping I don’t have to do this every time the container updates…
Yes, it needs to be done on the host OS. You can check/count the current ‘used’ ones with:
netstat -ng
(just check/count the 224.0.., the other ones are IPv6)
To make it permanent after each reboot, add it to the “/etc/sysctl.conf”.
Hmm, having issues doing this on freeBSD. Need to look into it further
I am having the same issue but on Windows 2012 R2
Any known fix?
I’m having a problem with my HASS installation on RPi 4 running docker in Libreelec. I using this fine on a RPi3 and I migrated to a new installation on RPi 4 copying all the userdata folders for docker and Portainer. Everything seems to run ok apart from discovery doesn’t work and I get the error in the log below. I’m running host network mode in docker and I’ve checked to make sure all services on Libreelec aren’t running as I know avahi running can conflict with HASS discovery.
2019-07-14 14:48:01 ERROR (MainThread) [homeassistant.components.discovery] Network is unreachable
2019-07-14 14:51:28 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 80, in create_connection
    raise err
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 70, in create_connection
    sock.connect(sa)
OSError: [Errno 113] Host is unreachable
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 603, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 355, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/local/lib/python3.7/http/client.py", line 1244, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1290, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1239, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/local/lib/python3.7/http/client.py", line 966, in send
    self.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 183, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xafb83dd0>: Failed to establish a new connection: [Errno 113] Host is unreachable
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 641, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 399, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.40', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xafb83dd0>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 67, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 216, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 115, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 478, in get
    return await self.handle(request, camera)
  File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 495, in handle
    image = await camera.async_camera_image()
  File "/usr/src/homeassistant/homeassistant/components/mjpeg/camera.py", line 107, in async_camera_image
    self.camera_image)
  File "/usr/src/homeassistant/homeassistant/components/mjpeg/camera.py", line 143, in camera_image
    req = requests.get(self._mjpeg_url, stream=True, timeout=10)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.40', port=8081): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xafb83dd0>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
I don’t think the raspberry pi 4 is supported yet based on their blog
Who’s blog? I’m running on Libreelec in a docker container and HASS works fine apart from discovery.
Sorry, haven’t had my coffee yet. Hassio doesn’t support raspberry pi 4 yet but looks like libreelec does have a beta. Unfortunately I never figured out my discovery issues
Also the Pi 4 issue is related to “Host is unreachable”, this topic is around “Network is unreachable”. So different issues, sorry.
Does anyone of you happen to have Pihole running? In my case I am and I think it might be the culprit. Disabled Pihole now and testing with cloudflare dns to see if that works better.
I do…Hmm I’ll have to test this.
@fversteegen @dj21d - did you check the “netstat -ng” output and sysctl commands? If running multiple apps/containers, it is possible you go over such limit (on the main OS).
I did run it, but don’t know how to interpret it :upside_down_face:
