I apologize if this has been addressed before but I wasn’t able to find it in search and I also may be lacking in understanding what I’m looking for.
I’m currently running Open Media Vault as an OS and I’m using Docker for multiple containers including: Transmission, Plex, Radarr, Sonarr etc… all of which run perfectly.
I recently installed Home Assistant in a container and I’m unable to get any devices or servers to “discover”.
My log reads:
2019-10-29 13:12:19 ERROR (MainThread) [homeassistant.components.yr.sensor] Retrying in 17 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Network is unreachable]
Configuration YAML:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
Additionally since I used the GUI in OMV to do the installation I feel like the piece I’m missing is --net=host
which i keep seeing being used in the CLI installations but I can’t seem to use that as an extra argument in running any new image.
