I am using the latest version of HA and HassIO with RP3. I installed Mosquitto broker and can see my Tasmota Sonoff devices connected and also HA.
I don’t see but I can’t see the sonoffs in the integration and as a entinty under HA.
any idea what could be the problem?
the log for Mosquitto is
@Ophir_Fux
What did you use for manual config? I got mine to work with the auto config “SetOption19” but I wanted to change to manual so that I understood how it was working. I can’t get the manual settings to work.
I have it set like this
light:
So, dumb question… where do you put this "switch: " stuff in the previous post? configuration.yml? I suspect this is qhy the mqtt add-on is seeing my four sonoff basic’s, but HA never sees the devices??
very frustrated because there isn’t one post out there that explains how to do this well.
