Discovery of zigbee2mqtt devices fails
Hi there!
I’m looking for someone who may be able to tell me where my mistake is.
I have a docker-based setup managed through balenacloud.
  • Mosquitto
  • Homeassistant
  • Zigbee2mqtt
    I’m trying to have the zigbee devices recognized by homeassistant.
    The issue I’m running into, is that homeassistant tells me that there is something wrong with the json that it receives when it tries to discover devices through MQTT.
I paste here some messages from Home Assistant > Developer Tools > Logs
Log Details (ERROR)
Logger: homeassistant.util.logging
Source: util/logging.py:164
First occurred: 5:03:20 PM (64 occurrences)
Last logged: 5:03:21 PM
**Exception in async_discover_sensor when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'availability': [{'**topic': 'z2m/bridge/state'}], 'device': {'identifiers': ['zigbee2mqtt_0xa4c138a1ecd1ba34'], 'manufacturer': 'TuYa', 'model': 'Light controller (TS0502B)', 'name': 'RS7'}, 'enabled_by_default': False, 'entity_category': 'diagnostic', 'icon': 'mdi:signal', 'name': 'RS7 linkquality', 'state_class': 'measurement', 'state_topic': 'z2m/RS7', 'unique_id': '0xa4c138a1ecd1ba34_linkquality_z2m', 'unit_of_measurement': 'lqi', 'value_template': '{{ value_json.linkquality }}', 'platform': 'mqtt'},) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py", line 79, in async_discover_sensor config = PLATFORM_SCHEMA(discovery_payload) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict return base_validate(path, iteritems(data), out) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: **extra keys not allowed @ data['availability']**
**Exception in async_discover when dispatching 'mqtt_discovery_new_light_mqtt': ({'availability': [{'topic': 'z2m/bridge/state'}],** 'brightness': True, 'brightness_scale': 254, 'color_mode': True, 'command_topic': 'z2m/RS8/set', 'device': {'identifiers': ['zigbee2mqtt_0xa4c1389ac4f2c2ce'], 'manufacturer': 'TuYa', 'model': 'Light controller (TS0502B)', 'name': 'RS8'}, 'effect': True, 'effect_list': ['blink', 'breathe', 'okay', 'channel_change', 'finish_effect', 'stop_effect'], 'max_mireds': 500, 'min_mireds': 153, 'name': 'RS8', 'schema': 'json', 'state_topic': 'z2m/RS8', 'supported_color_modes': ['color_temp'], 'unique_id': '0xa4c1389ac4f2c2ce_light_z2m', 'platform': 'mqtt'},) Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/mqtt/light/__init__.py", line 52, in async_discover config = PLATFORM_SCHEMA(discovery_payload) File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 208, in __call__ return self._exec((Schema(val) for val in self.validators), v) File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 287, in _exec raise e if self.msg is None else AllInvalid(self.msg, path=path) File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 283, in _exec v = func(v) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable return schema(data) File "/usr/src/homeassistant/homeassistant/components/mqtt/light/__init__.py", line 30, in validate_mqtt_light return schemas[value[CONF_SCHEMA]](value) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 272, in __call__ return self._compiled([], data) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict return base_validate(path, iteritems(data), out) File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping raise er.MultipleInvalid(errors) voluptuous.error.MultipleInvalid: **extra keys not allowed @ data['availability']**
Since homeassistant gets the messages in, it means that broker and the two clients are communicating to some degree.
It seems homeassistant takes issue with the ‘availability’ topic that is given by zigbee2mqtt.
However, I spent a good few hours researching the problem (it’s not this, nor this), and I don’t know how to solve it.
I disabled the legacy attribute stuff in the zigbee2mqtt configuration, but no dice.
Anyone who knows where I’m going wrong?
I also see this message in homeassistant log:
Was using a very outdated version of Home Assistant. Solved!
