Dishwashers and home assistance (+solar panels)
What do you mean with ‘alt integration’? A none official one? For my Siemens I do not see any power entities at all using the Home Connect Integration.
am in the same situation. I guess it is not doable out of the box.
I made some investigations.
The energy- percentage given by the bosch-siemens-API is just an estimate of the energy consumption.
At least for my dishwasher there is an option to show the estimated power/water consumption on the machine itself (some bars).
The percentage gives you how big these bars are.
So when you change the program, the energy percentage changes (but seems to be always the same).
To me, it seems that the energy-consumption shown in the official app is also just an estimate, i.e. whenever you use program „Eco“ it will simply sum-up some fixed value od say 0.8 kWh, when you use a different program it will add e.g. 0.9 kWh.
Will start plyaing around with powercalc, maybe also get some smart plug to measure, when I find some time to play aroung
Andreas
