Disk folders disappear when using SambaNas add-on
Having an issue with just one attached drive. For some reason it will randomly not show the folders on the drive until I stop and restart sambanas then they show back up again for awhile but then will just disappear again. Anyone else see this?
If you are having a problem with a specific add-on, the first point of contact is in the Github post that you found it in originally.
Most if not all the people there that know the product and use the software that will be able to give you more accurate information regarding your problem.
Here you might find someone.
Thanks! Done.
