I have HassOS installed on an Intel NUC. After upgrading to 2022.12.1 it seems that after running for a few hours Home Assistant stops responding and I’m unable to access it at all.
When I look at the Disk IO activity light on the NUC it is constantly on during this time and I am only able to restore Hass after rebooting the NUC.
This has happened twice after which I restored a backup from 2022.11 and the problem went away.
Any ideas / suggestions on how to diagnose what’s causing this ?
I noticed there are some (heavy) database updates, which run in the background; i suspect that was the case here…(it should be possible to check in the logs)
How long does this happen after installation ?
I can’t access the logs as Hass is inaccessible when this happens. After reboot logs are wiped clean so I don’t have a history pre-reboot.
How long the updates last depends a bit on the hardware used.
I know some months ago it would take at least one hour before the updates where finished (using MySQL with 6 months history).
If you are using SQLite, and are not intrested in the history, you can simply delete the home-assistant_v2.db file (and it will create a new one)
