Disk use growing but filesystem not
I have these sensors in HA:
- platform: systemmonitor
  resources:
    - type: disk_use_percent
      arg: /
    - type: disk_use
      arg: /
- platform: filesize
  file_paths:
    - /config/home-assistant_v2.db
I’ve observed that both eventually grow without explanation to me. The home-assistant_v2.db file has a constant size. I attach a graph:
disk_use
I’ve checked in ssh terminal executing df and du commands.
➜  ~ df
Filesystem           1K-blocks      Used Available Use% Mounted on
overlay               29941192   5756692  22939532  20% /
tmpfs                  1960060         0   1960060   0% /sys/fs/cgroup
/dev/root                98816     98816         0 100% /sbin/docker-init
/dev/mmcblk0p8        29941192   5756692  22939532  20% /data
/dev/mmcblk0p8        29941192   5756692  22939532  20% /ssl
/dev/mmcblk0p8        29941192   5756692  22939532  20% /addons
/dev/mmcblk0p8        29941192   5756692  22939532  20% /share
/dev/mmcblk0p8        29941192   5756692  22939532  20% /config
/dev/mmcblk0p8        29941192   5756692  22939532  20% /media
devtmpfs               1926268         0   1926268   0% /dev
tmpfs                  1960060         0   1960060   0% /dev/shm
/dev/mmcblk0p8        29941192   5756692  22939532  20% /backup
/dev/mmcblk0p8        29941192   5756692  22939532  20% /etc/asound.conf
/dev/mmcblk0p8        29941192   5756692  22939532  20% /run/audio
tmpfs                   784028      1116    782912   0% /run/dbus
/dev/mmcblk0p8        29941192   5756692  22939532  20% /etc/hosts
/dev/mmcblk0p8        29941192   5756692  22939532  20% /etc/hostname
/dev/mmcblk0p8        29941192   5756692  22939532  20% /etc/resolv.conf
/dev/mmcblk0p8        29941192   5756692  22939532  20% /etc/pulse/client.conf
tmpfs                  1960060         0   1960060   0% /proc/asound
devtmpfs               1926268         0   1926268   0% /proc/keys
devtmpfs               1926268         0   1926268   0% /proc/latency_stats
devtmpfs               1926268         0   1926268   0% /proc/timer_list
devtmpfs               1926268         0   1926268   0% /proc/sched_debug
tmpfs                  1960060         0   1960060   0% /sys/firmware
➜  / du
... (shortened)
44      ./share
106224  ./backup
12      ./ssl
8       ./config/custom_components/fordpass/translations
48      ./config/custom_components/fordpass/__pycache__
128     ./config/custom_components/fordpass
16      ./config/custom_components/irrigation_unlimited/translations
80      ./config/custom_components/irrigation_unlimited/__pycache__
192     ./config/custom_components/irrigation_unlimited
100     ./config/custom_components/alexa_media/translations
168     ./config/custom_components/alexa_media/__pycache__
100     ./config/custom_components/alexa_media/.translations
628     ./config/custom_components/alexa_media
28      ./config/custom_components/average/__pycache__
64      ./config/custom_components/average
116     ./config/custom_components/sonoff/__pycache__
256     ./config/custom_components/sonoff
84      ./config/custom_components/hacs/helpers/functions/__pycache__
168     ./config/custom_components/hacs/helpers/functions
8       ./config/custom_components/hacs/helpers/__pycache__
20      ./config/custom_components/hacs/helpers/properties/__pycache__
40      ./config/custom_components/hacs/helpers/properties
44      ./config/custom_components/hacs/helpers/classes/__pycache__
88      ./config/custom_components/hacs/helpers/classes
20      ./config/custom_components/hacs/helpers/methods/__pycache__
44      ./config/custom_components/hacs/helpers/methods
356     ./config/custom_components/hacs/helpers
32      ./config/custom_components/hacs/operational/__pycache__
32      ./config/custom_components/hacs/operational/setup_actions/__pycache__
60      ./config/custom_components/hacs/operational/setup_actions
128     ./config/custom_components/hacs/operational
8       ./config/custom_components/hacs/translations
32      ./config/custom_components/hacs/hacsbase/__pycache__
68      ./config/custom_components/hacs/hacsbase
48      ./config/custom_components/hacs/__pycache__
12      ./config/custom_components/hacs/webresponses/__pycache__
24      ./config/custom_components/hacs/webresponses
20      ./config/custom_components/hacs/models/__pycache__
40      ./config/custom_components/hacs/models
32      ./config/custom_components/hacs/repositories/__pycache__
64      ./config/custom_components/hacs/repositories
48      ./config/custom_components/hacs/api/__pycache__
96      ./config/custom_components/hacs/api
12      ./config/custom_components/hacs/validate/__pycache__
8       ./config/custom_components/hacs/validate/integration/__pycache__
16      ./config/custom_components/hacs/validate/integration
20      ./config/custom_components/hacs/validate/common/__pycache__
40      ./config/custom_components/hacs/validate/common
84      ./config/custom_components/hacs/validate
964     ./config/custom_components/hacs
72      ./config/custom_components/scheduler/__pycache__
164     ./config/custom_components/scheduler
2400    ./config/custom_components
4       ./config/.cloud
12      ./config/blueprints/automation/homeassistant
16      ./config/blueprints/automation
20      ./config/blueprints
24      ./config/tts
4       ./config/deps
124     ./config/www/community/mini-graph-card
268     ./config/www/community/scheduler-card
52      ./config/www/community/lovelace-fold-entity-row
32      ./config/www/community/lovelace-multiple-entity-row
24      ./config/www/community/lovelace-tempometer-gauge-card
84      ./config/www/community/logbook-card
908     ./config/www/community
224     ./config/www/mando
1516    ./config/www
12      ./config/image/726a5828dd463dacf6621f13c543d85b
16      ./config/image
56      ./config/.storage/hacs
1992    ./config/.storage
487164  ./config
136     ./libexec
936290  .
I don’t understand why the total size of the filesystem is 936290 KB, but the used space is 5756692 KB.
Your snapshots are taking up the most room. Do you have them automated?
No, they are not automated. In any case, now I only have two snapshots, with a total size of about 100 MB, while the space used of the disk is 5.5 GB.
➜  ~ cd backup
➜  backup ll
total 104M
-rw-r--r--    1 root     root       47.9M Apr  2 11:38 28650ce2.tar
-rw-r--r--    1 root     root       55.8M Mar 31 11:12 f699109c.tar
➜  backup du
106224  .
BTW, I’m using Home Assistant in a RP4 with a microSD card with 32GB.
Could be something outside the Home Assistant container. What addons do you have installed?
I have these addons:
  • Duck DNS
  • File Editor
  • SQLite Web
  • SSH & Web Terminal
  • Samba Share
I also have these HACS integrations:
  • HACS
  • Sonoff LAN
  • Irrigation Unlimited
  • Scheduler component
  • fordpass
  • Average Sensor
  • Alexa Media Player
HACS frontend:
  • fold-entry-row
  • Tempometer Gauge Card
  • Scheduler Card
  • mini-graph-card
  • Multiple Entity Row
  • Logbook Card
2 usefull links I use from time to time :slight_smile:
HASSIO Docker Overlay2 folder consuming all disk space - Home Assistant OS - Home Assistant Community (home-assistant.io)
[Solved] Moved over to docker, all well except huge memory leak - Configuration - Home Assistant Community (home-assistant.io)
The ‘prune’ docker command seems to clean some old stuff not automatically cleaned when new versions are installed, especially for some community addons.
But : TAKE CARE to what you are doing ! :slight_smile: Always backup before…
I’ve tried what suggested in the firs link.
I don’t have a journalctl command in my system :thinking:
This is the result:
➜  ~ docker images
REPOSITORY                                 TAG         IMAGE ID       CREATED        SIZE
homeassistant/armv7-hassio-cli             2021.03.1   1a4668350f99   3 days ago     72.3MB
ghcr.io/hassio-addons/ssh/armv7            8.1.0       0039c7f2369f   8 days ago     308MB
homeassistant/armv7-hassio-supervisor      2021.03.6   990618a1d04e   2 weeks ago    250MB
homeassistant/armv7-hassio-supervisor      latest      990618a1d04e   2 weeks ago    250MB
homeassistant/raspberrypi4-homeassistant   2021.3.4    c86300c573cd   2 weeks ago    1.03GB
homeassistant/armv7-addon-samba            9.3.1       946d4c8915db   5 weeks ago    98MB
ghcr.io/hassio-addons/sqlite-web/armv7     3.0.1       1b49772aa200   5 weeks ago    88.6MB
homeassistant/armv7-hassio-audio           2021.02.1   40f28e0fd362   6 weeks ago    90.5MB
homeassistant/armv7-addon-duckdns          1.12.5      9e8282c0ea0a   7 weeks ago    71.9MB
homeassistant/armv7-hassio-dns             2021.01.0   eeb0a3e43eb4   2 months ago   85.9MB
homeassistant/armv7-addon-configurator     5.2.0       e197f4a5c640   4 months ago   130MB
homeassistant/armv7-hassio-observer        2020.10.1   bf193dc8f2c4   5 months ago   71.8MB
homeassistant/armv7-hassio-multicast       3           0fbd536e8547   7 months ago   63.3MB
➜  ~ docker image prune -a
WARNING! This will remove all images without at least one container associated to them.
Are you sure you want to continue? [y/N] y
Deleted Images:
untagged: homeassistant/armv7-hassio-supervisor:2021.03.6
Total reclaimed space: 0B
➜  ~ docker container prune --filter "until=24h"
WARNING! This will remove all stopped containers.
➜  ~ docker volume prune
WARNING! This will remove all local volumes not used by at least one container.
➜  ~ docker images
➜  ~ journalctl --disk-usage
zsh: command not found: journalctl
➜  ~ df
overlay               29941192   5806516  22889708  20% /
/dev/mmcblk0p8        29941192   5806516  22889708  20% /share
/dev/mmcblk0p8        29941192   5806516  22889708  20% /data
/dev/mmcblk0p8        29941192   5806516  22889708  20% /media
/dev/mmcblk0p8        29941192   5806516  22889708  20% /addons
/dev/mmcblk0p8        29941192   5806516  22889708  20% /backup
/dev/mmcblk0p8        29941192   5806516  22889708  20% /ssl
/dev/mmcblk0p8        29941192   5806516  22889708  20% /config
tmpfs                   784028      1120    782908   0% /run/dbus
tmpfs                   784028      1120    782908   0% /run/docker.sock
/dev/mmcblk0p8        29941192   5806516  22889708  20% /etc/asound.conf
/dev/mmcblk0p8        29941192   5806516  22889708  20% /run/audio
/dev/mmcblk0p8        29941192   5806516  22889708  20% /etc/hosts
/dev/mmcblk0p8        29941192   5806516  22889708  20% /etc/hostname
/dev/mmcblk0p8        29941192   5806516  22889708  20% /etc/resolv.conf
/dev/mmcblk0p8        29941192   5806516  22889708  20% /etc/pulse/client.conf
Almost the same space used (I have made a snapshot of the system before running the suggested commands).
Have you solved it? I have exactly same experience / issue. Can’t find solution or reason for this… :frowning:
The ammount of space used depends over all of the numer of sensors you use and the period of time you record your sensor data. Those data are stored in the file home-assistant_v2.db in your config folder.
Look at the recorder documentation: Recorder - Home Assistant
The most important parameters regarding space are: purge_keep_days and commit_interval.
You can also use exclude to avoid recording some sensor data you won’t need.
To watch which sensors are generating more data, you can use the SQLite Web addon. After installing, open web UI, and there click on events (on the left column) and then on Query. From there you can place any query to your database:
For instance:
SELECT "entity_id", COUNT("state") as "StateCount" FROM states GROUP BY "entity_id" ORDER BY "StateCount" DESC
Gives you the sensors ordered by numer of entries in the database.
SELECT "entity_id", COUNT("state") as "StateCount" FROM states WHERE "last_updated" >= '2021-09-19 00:00:00.000000' GROUP BY "entity_id" ORDER BY "StateCount" DESC
Gives you the same but since some momment in the past.
Hope this helps.
Thank you. But it’s not my case. I am missing about 30GB and the home-assistant_v2.db is about 2,5GB.
Camera recordings ?
Docker overlay2 ?
All of those would be visible in “du -d 1 -h” , but I see 13,5GB used. “df -h” says 42GB used… no idea what to do…
overlay2 doesnt exists
camera recordings - probably not, but where to look?
