I’m playing with my new wall panel (NSPanel Pro120) and I have an idea but I can’t find a solution to this. I have a ring doorbell fully integrated with HA, so I can detect ring, motion and I can see the snapshot / live feed from HA. My idea is to display the camera snapshot or live feed when someone at the door / ringing. Preferably I would keep using licensed fully kiosk browser for this. Is there any method to achieve this goal?
I use the new section view, and I have one section with just the video of the doorbell. Now I use the condition of the section to show this only when someone rings using a helper (switch). I switch that helper back to off after some time, eg. 30 sec.
This is not a bad idea, however on this small screen the home dashboard already fills the screen and it would ideal if this trigger either creates some kind of overlay (there is some option for this in Fully Kiosk Browser) or it should switch to the page where I have the cameras. Do you think it is possible somehow?
If you just work with sections on that view you can switch the others of or you place this conditional section right on the top of all. Then if it is shown the sections are pushed below as long as this is visible.
This way you just see it if someone rings and otherways it is invisible.
Actually I build my new dashboard on this technic. I do like it better than pop ups.
