Display component/LVGL and ugly graphics + unusable navigation footer
Hi Guys,
A while ago I started my struggles on a bathing display (as the current control panel is broken). As you now during projects there are always some struggles on the path.
But whatever I try, I can’t get these 2 things fixed:
  • The display looks ugly like if it stays in 8bit mode
  • The footer navigation only shows a somewhat devided bar on the footer but no navigation and home button.
The hardware:
  • ESP-S3 N16r8 (item is discontinued on Temu but I got a screenshot):
  • 3.5" 480x320 SPI ILI9488 met FT6236 CTP module (Link)
  • Openjumper 4 way relay board.
The wirings:
Note: The amplifier and speaker part arent setup yet as I want to fix this first.
What the display looks like right now:
Actually: On the photo the display looks even better than in real life :slight_smile: But here you see navigation foorter issue and slightly a bit of the coloring issue.
To be clear about the coloring issue (which makes gradients look very ugly i made a macro photo:
What I tried (and found out):
  • At first I was using the ILI9488 lib but I discovered that I needed to use the alternative gamma version of it so Right now I’m using the ILI9488_A
  • I discovered that I had to set invert_colors: mode to “true”
  • I made sure the board is using it’s flash by setting the platformio_options: and setting the flash_size: 16MB under ESP32: component + setting the PSRAM to Ocal with 80Mhz
  • In the display component i’ve set: auto_clear_enabled: false and update_interval: never as this is a requirement to use LVGL properly.
  • I tried RGB and played with the invert colors but in the end the currently settings set got the best results of all bad results.
My code (currently a bit unstructured but I usually get it structured if everything works well):
esphome:
  friendly_name: Bath
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.arduino.memory_type: qio_opi
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  #partitions: "/config/esphome/custom_16MB.csv"
  framework:
    type: arduino
    # version: latest
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "SuperSecretEncryptionKey"
ota:
  - platform: esphome
    password: "SuperSecretOTAPassword"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "BathDisplay"
    password: "SuperSecretAPPassword"
captive_portal:
web_server:
  port: 80
## Configuring push buttons
binary_sensor:
  - platform: gpio
    pin: GPIO3  # The GPIO pin connected to the push button
    on_press:
      then:
        - switch.toggle: relay_s1
## Configuring the Relay Switch
switch:
  - platform: gpio
    pin: 7
  - platform: gpio
    pin: 6
  - platform: gpio
    pin: 5
  - platform: gpio
    pin: 4
# Remove the first 3 #'s to make the display work
# Configuring the SPI Pins
spi:
  clk_pin: GPIO12
  mosi_pin: GPIO11
  miso_pin: GPIO13
# Assigning the i2c pins that can be used for i2c communication
i2c:
  sda: GPIO38 # Probably the boot issue due to reserved for USB_D+ --> From 20 to 38
  scl: GPIO9
  scan: True
### Configuring the Display Part
display:
  - platform: ili9xxx
    model: ILI9488_A
    dimensions:
      height: 320
      width: 480
      offset_height: 0
      offset_width: 0
    transform:
      swap_xy: true
      mirror_x: false
      mirror_y: false
    auto_clear_enabled: false # Disabling autoclear to be compatible with LVGL
    color_order: BGR # RGB or BGR
    invert_colors: true
    data_rate: 40MHz
    cs_pin: GPIO1
    dc_pin: GPIO42
    reset_pin: GPIO2
    # show_test_card: true
    # rotation: 90
    #lambda: |-
    #  it.print(0, 0, id(my_font), "Hello, World!");
## Configuring things for ontrolling the display's ledled
# Define the LED pin as a PWM output
output:
  - platform: ledc
    pin: GPIO39
light:
  - platform: monochromatic
    output: gpio_backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
## Configuring the touchscreen part
touchscreen:
  - platform: ft63x6
    reset_pin: GPIO40
    interrupt_pin: GPIO21 # boot issue due to reserved for USB_D- --> From 19 to 21
    on_release:
      - if:
          condition: lvgl.is_paused
          then:
            - logger.log: "LVGL resuming"
            - lvgl.resume:
            - lvgl.widget.redraw:
            - light.turn_on: display_backlight
## Configuring the SD card Slot (based on assumption if it 'll be supported ever by ESPHOME')
# sd_card:
#  cs_pin: GPIO48 (This is the real connected GPIO port in preparation of potential support in the future)
#  spi_id: spi_bus
font:
  - file: "fonts/arial.ttf"
# Setting a wall paper for use in lvgl
image:
  - file: 'bath/bg/BackgroundWaterdrop.png'
    resize: 480x320
    type: RGB565
    use_transparency: false
### Start of the LVGL part
lvgl:
  buffer_size: 100%
  disp_bg_image: wallpaper
### START Theme Part
  theme:
    label:
      text_font: my_font # set all your labels to use your custom defined font
    button:
      bg_color: 0x2F8CD8
      bg_grad_color: 0x005782
      bg_grad_dir: VER
      bg_opa: COVER
      border_color: 0x0077b3
      border_width: 1
      text_color: 0xFFFFFF
      pressed: # set some button colors to be different in pressed state
        bg_color: 0x006699
        bg_grad_color: 0x00334d
      checked: # set some button colors to be different in checked state
        bg_color: 0x1d5f96
        bg_grad_color: 0x03324A
        text_color: 0xfff300
    buttonmatrix:
      bg_opa: TRANSP
      border_width: 0
      pad_all: 0
      items: # set all your buttonmatrix buttons to use your custom defined styles and font
        bg_color: 0x2F8CD8
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
        text_font: my_font
        pressed:
          bg_color: 0x006699
        checked:
          bg_color: 0x1d5f96
          text_color: 0x005580
    switch:
      bg_color: 0xC0C0C0
      bg_grad_color: 0xb0b0b0
      bg_grad_dir: VER
      bg_opa: COVER
      checked:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0xFFFFFF
        bg_grad_color: 0xC0C0C0
        bg_grad_dir: VER
        bg_opa: COVER
    slider:
      border_width: 1
      border_opa: 15%
      bg_color: 0xcccaca
      bg_opa: 15%
      indicator:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0x2F8CD8
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
  style_definitions:
    - id: header_footer
      bg_color: 0x2F8CD8
      bg_grad_dir: VER
      bg_opa: COVER
      border_opa: TRANSP
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 30
### END Theme Part
### START Page navigation footer
  top_layer:
      widgets:
        - buttonmatrix:
            align: bottom_mid
            styles: header_footer
            pad_all: 0
            outline_width: 0
            items:
            rows:
              - buttons:
                - id: page_prev
                  text: "\uF053"
                  on_press:
                    then:
                      lvgl.page.previous:
                - id: page_home
                  text: "\uF015"
                  on_press:
                    then:
                      lvgl.page.show: main_page
                - id: page_next
                  text: "\uF054"
                  on_press:
                    then:
                      lvgl.page.next:
### END Page navigation footer
### START Pages part
  pages:
    - id: main_page
      widgets:
      - switch:
          #x: 100
          #y: 100
          on_value:
            then:
      - button:
          #x: 150
          #y: 150
          #width: 100
          #height: 100
          checkable: false
          align: center
          widgets:
            - label:
                align: center
                text: "Relay_S1"
          on_release:
            then:
### END Pages part
### START LVGL Display auto turn of part
  on_idle:
    timeout: !lambda "return (id(display_timeout).state * 1000);" # was 1000 for 10s
    then:
      - logger.log: "LVGL is idle"
      - light.turn_off: display_backlight
      - lvgl.pause:
### END LVGL Display auto turn of part
### END of the LVGL part
### START ESPHOME Display auto turn of part
number:
    name: LVGL Screen timeout
    optimistic: true
    unit_of_measurement: "s"
    initial_value: 20
    restore_value: true
    min_value: 1
    max_value: 180
    step: 5
    mode: box
### END ESPHOME Display auto turn of part
I Hope someone struggled with the same as I do and is willing to share the knowledge to resolve this.
*EDIT 12-12-2024
I couldn’t fix the issue, perhaps the screen was broken so I decided to return it.
Now I’ll try it with another display with another driver.
I Marked Clyde’s answer on my navigation footer as this was my solution to 50% of this thread :slight_smile: The other one never got solved (probably because the display appeared to be broken.
Firstly the ILI9488 is a bad choice for a display since it only works in 18 bit mode, which makes it slow.
Your text will look better if you set the font bpp to 4. And the footer symbols are not specified in the font. You will either need to use regular Latin characters, or add the special characters from another font.
Hi Clyde,
Thanks for your input.
So actually the ILI9488 isn’t on the best-practises list. Which display would you prefer?
When searching for the right display I only made sure it was on esphome’s support list and that it has capacitive touch with a supported touch driver.
Regarding the font: I indeed got better results with BPP: 4 thanks for that one.
I also tried switching to latin fonts but this doesnt solve my navigation footer issue.
Actually I think the fotter issue relays somewhere else as the whole layout as it should look like this:
Take note of the 3 buttons prev_page button/Home/Next page button so 3 columns whilst my display shows 4 columns and no buttons at all.
Pretty much anything else :slight_smile: It is usable, just slow, which may not be an issue for many applications.
The footer is showing the buttons, it’s just you haven’t said how you want them drawn. The unicode characters like "\uF053" are not part of the default glyphset, and probably not present in the font you are using anyway, so they get drawn with the “unknown character” representation which is a simple rectangle.
See here for details on how to include them.
Thanks (again) for your input.
I dived into it and got the navigation footer solved by your direction. So I;m very happy on that one :+1:
However since setting up the glyphset the display became pretty much slower. Formerly it fired up immediately on a touch, whilst now I need to touch it for a full second and then it slowly comes up. Is this typical behavior of the ILI9844 driver?
Anyway if it won’t become slower than it is now when adding more things to the display then I can live with it.
I’ve also set the background image to the main page: This makes the uglyness of the displays picture displaying much more obvious (it’s best visible at the upper part of the image):
I searached the web and asked AI but non of them came with any solution on this one, do you have suggestions on that one?
I did also found the package in which the display was delivered which had a sticker on it with this message:
As the manufacturer decides to put a sticker on it I guess this is a common issue on this display. However I don’t know what’s ment with TN code as esphome only supports SPI displays and I therefore automatically assumed I was using the right code on this display, but now I see they wrote IPS and not SPI :upside_down_face:, does this clarify anything or doesn’t it make any sense?
Does your board have PSRAM? Attach the log output, especially the config dump. Try using ESP-IDF instead of Arduino as the platform.
This screen work very well with LVGL and it has the esp32 built in already. No wiring.,
This and the other Waveshare LCD boards in that series (4.3, 4.3B, 5) work great, have a lot of features, are well documented, and are solidly constructed. I think they’re all great value for the price.
IPS refers to the type of LCD panel, not the interface. The main difference from a software point of view between IPS and TN is whether invert_colors needs to be set, which you can establish with experimentation anyway.
I changed to ESP-IDF, but functionally I noticed no difference at all.
I’m using an ESP-SR N16R8 So I guess I got 16MB of PSRAM and 8Mb of Flash
In the logs I see 8Mb PSram (line: 120). So I’m going to look into that on how to set it to 16Mb.
Below the log file when I upload the code:
INFO ESPHome 2024.11.2
INFO Reading configuration /config/esphome/bath.yaml...
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing bath (board: esp32-s3-devkitc-1; framework: espidf; platform: platformio/[email protected])
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
 - framework-espidf @ 3.40408.0 (4.4.8)
 - tool-cmake @ 3.16.4
 - tool-ninja @ 1.7.1
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
 - toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.6
|-- ArduinoJson @ 6.18.5
|-- lvgl @ 8.4.0
Compiling .pioenvs/bath/src/main.o
Linking .pioenvs/bath/firmware.elf
RAM:   [=         ]  10.4% (used 33920 bytes from 327680 bytes)
Flash: [==        ]  16.3% (used 1327369 bytes from 8126464 bytes)
Building .pioenvs/bath/firmware.bin
Creating esp32s3 image...
Successfully created esp32s3 image.
esp32_create_combined_bin([".pioenvs/bath/firmware.bin"], [".pioenvs/bath/firmware.elf"])
Wrote 0x154270 bytes to file /data/build/bath/.pioenvs/bath/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([".pioenvs/bath/firmware.bin"], [".pioenvs/bath/firmware.elf"])
========================= [SUCCESS] Took 24.87 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.2.164 port 3232...
INFO Connected to 192.168.2.164
INFO Uploading /data/build/bath/.pioenvs/bath/firmware.bin (1327728 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 5.22 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.2.164 using esphome API
INFO Successfully connected to bath @ 192.168.2.164 in 7.260s
INFO Successful handshake with bath @ 192.168.2.164 in 0.061s
[15:56:24][I][app:100]: ESPHome version 2024.11.2 compiled on Dec  4 2024, 15:55:47
[15:56:24][C][wifi:600]: WiFi:
[15:56:24][C][wifi:428]:   Local MAC: **:3D:**:E9:E4:**
[15:56:24][C][wifi:433]:   SSID: 'D****-****2'[redacted]
[15:56:24][C][wifi:436]:   IP Address: 192.168.2.164
[15:56:24][C][wifi:440]:   BSSID: **:60:F9:**:E3:**[redacted]
[15:56:24][C][wifi:441]:   Hostname: 'bath'
[15:56:24][C][wifi:443]:   Signal strength: -59 dB ▂▄▆█
[15:56:24][C][wifi:447]:   Channel: 5
[15:56:24][C][wifi:448]:   Subnet: 255.255.255.0
[15:56:24][C][wifi:449]:   Gateway: 192.168.2.254
[15:56:24][C][wifi:450]:   DNS1: 192.168.2.77
[15:56:24][C][wifi:451]:   DNS2: 192.168.2.77
[15:56:24][C][logger:185]: Logger:
[15:56:24][C][logger:186]:   Level: DEBUG
[15:56:24][C][logger:188]:   Log Baud Rate: 115200
[15:56:24][C][logger:189]:   Hardware UART: USB_SERIAL_JTAG
[15:56:24][C][spi:064]: SPI bus:
[15:56:24][C][spi:065]:   CLK Pin: GPIO12
[15:56:24][C][spi:066]:   SDI Pin: GPIO13
[15:56:24][C][spi:067]:   SDO Pin: GPIO11
[15:56:24][C][spi:072]:   Using HW SPI: SPI2_HOST
[15:56:24][C][i2c.idf:075]: I2C Bus:
[15:56:24][C][i2c.idf:076]:   SDA Pin: GPIO38
[15:56:24][C][i2c.idf:077]:   SCL Pin: GPIO9
[15:56:24][C][i2c.idf:078]:   Frequency: 50000 Hz
[15:56:24][C][i2c.idf:084]:   Recovery: bus successfully recovered
[15:56:24][I][i2c.idf:094]: Results from i2c bus scan:
[15:56:24][I][i2c.idf:100]: Found i2c device at address 0x38
[15:56:24][C][switch.gpio:068]: GPIO Switch 'S1'
[15:56:24][C][switch.gpio:091]:   Restore Mode: always OFF
[15:56:24][C][switch.gpio:031]:   Pin: GPIO7
[15:56:24][C][switch.gpio:068]: GPIO Switch 'S2'
[15:56:24][C][switch.gpio:031]:   Pin: GPIO6
[15:56:24][C][switch.gpio:068]: GPIO Switch 'S3'
[15:56:24][C][switch.gpio:031]:   Pin: GPIO5
[15:56:24][C][switch.gpio:068]: GPIO Switch 'S4'
[15:56:24][C][switch.gpio:031]:   Pin: GPIO4
[15:56:24][C][ili9xxx:094]: ili9xxx
[15:56:24][C][ili9xxx:094]:   Rotations: 0 °
[15:56:24][C][ili9xxx:094]:   Dimensions: 480px x 320px
[15:56:24][C][ili9xxx:095]:   Width Offset: 0
[15:56:24][C][ili9xxx:096]:   Height Offset: 0
[15:56:24][C][ili9xxx:102]:   Color mode: 16bit
[15:56:24][C][ili9xxx:109]:   18-Bit Mode: YES
[15:56:24][C][ili9xxx:111]:   Data rate: 40MHz
[15:56:24][C][ili9xxx:113]:   Reset Pin: GPIO2
[15:56:24][C][ili9xxx:114]:   CS Pin: GPIO1
[15:56:24][C][ili9xxx:115]:   DC Pin: GPIO42
[15:56:24][C][ili9xxx:117]:   Color order: BGR
[15:56:24][C][ili9xxx:118]:   Swap_xy: YES
[15:56:24][C][ili9xxx:119]:   Mirror_x: NO
[15:56:24][C][ili9xxx:120]:   Mirror_y: NO
[15:56:24][C][ili9xxx:121]:   Invert colors: YES
[15:56:24][C][ili9xxx:126]:   Update Interval: never
[15:56:24][C][ledc.output:180]: LEDC Output:
[15:56:24][C][ledc.output:181]:   Pin GPIO39
[15:56:24][C][ledc.output:182]:   LEDC Channel: 0
[15:56:24][C][ledc.output:183]:   PWM Frequency: 1000.0 Hz
[15:56:24][C][ledc.output:184]:   Phase angle: 0.0°
[15:56:24][C][ledc.output:185]:   Bit depth: 14
[15:56:24][C][template.number:050]: Template Number 'LVGL Screen timeout'
[15:56:24][C][template.number:050]:   Unit of Measurement: 's'
[15:56:24][C][template.number:051]:   Optimistic: YES
[15:56:24][C][template.number:052]:   Update Interval: 60.0s
[15:56:24][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Push Button'
[15:56:24][C][gpio.binary_sensor:016]:   Pin: GPIO3
[15:56:24][C][light:092]: Light 'Display Backlight'
[15:56:24][C][light:094]:   Default Transition Length: 1.0s
[15:56:24][C][light:095]:   Gamma Correct: 2.80
[15:56:24][C][psram:020]: PSRAM:
[15:56:24][C][psram:021]:   Available: YES
[15:56:24][C][psram:024]:   Size: 8191 KB
[15:56:24][C][FT63X6:070]: FT63X6 Touchscreen:
[15:56:24][C][FT63X6:071]:   Address: 0x38
[15:56:24][C][FT63X6:072]:   Interrupt Pin: GPIO21
[15:56:24][C][FT63X6:073]:   Reset Pin: GPIO40
[15:56:24][C][FT63X6:074]:   Update Interval: 0.050s
[15:56:24][C][lvgl:086]: LVGL:
[15:56:24][C][lvgl:087]:   Display width/height: 480 x 320
[15:56:24][C][lvgl:088]:   Rotation: 0
[15:56:24][C][lvgl:089]:   Draw rounding: 2
[15:56:24][C][captive_portal:089]: Captive Portal:
[15:56:25][C][web_server:153]: Web Server:
[15:56:25][C][web_server:154]:   Address: bath.local:80
[15:56:25][C][mdns:116]: mDNS:
[15:56:25][C][mdns:117]:   Hostname: bath
[15:56:25][C][esphome.ota:073]: Over-The-Air updates:
[15:56:25][C][esphome.ota:074]:   Address: bath.local:3232
[15:56:25][C][esphome.ota:075]:   Version: 2
[15:56:25][C][esphome.ota:078]:   Password configured
[15:56:25][C][safe_mode:018]: Safe Mode:
[15:56:25][C][safe_mode:020]:   Boot considered successful after 60 seconds
[15:56:25][C][safe_mode:021]:   Invoke after 10 boot attempts
[15:56:25][C][safe_mode:023]:   Remain in safe mode for 300 seconds
[15:56:25][C][api:140]: API Server:
[15:56:25][C][api:141]:   Address: bath.local:6053
[15:56:25][C][api:143]:   Using noise encryption: YES
And below my Yaml code:
esphome:
  friendly_name: Bath
  platformio_options:
esp32:
  variant: esp32s3
  flash_size: 16MB # This is flash so prolly needs to be 8Mb
  framework:
    type: esp-idf
    # version: latest
psram:
  mode: octal
  speed: 120MHz
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: "o**************************="
ota:
  - platform: esphome
    password: "d******************a"
wifi:
  ap:
    ssid: "BathDisplay"
    password: "1************d"
captive_portal:
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    on_press:
      then:
switch:
  - platform: gpio
    pin: 7
  - platform: gpio
    pin: 6
  - platform: gpio
    pin: 5
  - platform: gpio
    pin: 4
spi:
  clk_pin: GPIO12
  mosi_pin: GPIO11
  miso_pin: GPIO13
i2c:
  scl: GPIO9
  scan: True
display:
  - platform: ili9xxx
    model: ILI9488_A
    dimensions:
      height: 320
      width: 480
      offset_height: 0
      offset_width: 0
    transform:
      swap_xy: true
      mirror_x: false
      mirror_y: false
    invert_colors: true
    data_rate: 40MHz
    cs_pin: GPIO1
    dc_pin: GPIO42
    reset_pin: GPIO2
    # rotation: 90
    #lambda: |-
output:
  - platform: ledc
    pin: GPIO39
light:
touchscreen:
  - platform: ft63x6
    reset_pin: GPIO40
    transform:
      mirror_x: true
      mirror_y: false
      swap_xy: true
    on_release:
      - if:
          then:
            - lvgl.resume:
# sd_card:
#  spi_id: spi_bus
font:
  - file: "fonts/calibri.ttf"
    bpp: 4
    extras:
      - file: "fonts/materialdesignicons-webfont.ttf"
        glyphs: [
          "\U000F0142", # mdi:chevron-right
          "\U000F0141", # mdi:chevron-left
          "\U000F02DC", # mdi:home
image:
    resize: 480x320
    type: RGB565
lvgl:
  buffer_size: 100%
  theme:
    label:
    button:
      bg_color: 0x2F8CD8
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 1
        bg_color: 0x006699
        bg_color: 0x1d5f96
    buttonmatrix:
      bg_opa: TRANSP
      border_width: 0
      pad_all: 0
        bg_color: 0x2F8CD8
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
        text_font: my_font
        pressed:
          bg_color: 0x006699
        checked:
          bg_color: 0x1d5f96
    switch:
      bg_color: 0xC0C0C0
      bg_grad_dir: VER
      bg_opa: COVER
      checked:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0xFFFFFF
        bg_grad_dir: VER
        bg_opa: COVER
    slider:
      border_width: 1
      border_opa: 80%
      bg_color: 0xcccaca
      bg_opa: 80%
      indicator:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0x2F8CD8
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
  style_definitions:
    - id: header_footer
      bg_color: 0x2F8CD8
      bg_grad_dir: VER
      bg_opa: COVER
      border_opa: TRANSP
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 30
### END Theme Part
  top_layer:
      widgets:
        - buttonmatrix:
            align: bottom_mid
            pad_all: 0
            outline_width: 0
            items:
            rows:
              - buttons:
                - id: page_prev
                  text: "\U000F0141" #"\uF053"
                  on_press:
                    then:
                      lvgl.page.previous:
                - id: page_home
                  text: "\U000F02DC" # "\uF015"
                  on_press:
                    then:
                - id: page_next
                  text: "\U000F0142" # "\uF054"
                  on_press:
                    then:
                      lvgl.page.next:
  pages:
    - id: main_page
      bg_image_src: wallpaper
      widgets:
      - switch:
          #x: 100
          #y: 100
          on_value:
            then:
      - button:
          #x: 150
          #y: 150
          #width: 100
          #height: 100
          checkable: false
          align: center
          widgets:
            - label:
                align: center
                text: "Relay_S1"
          on_release:
            then:
    - id: led_page
      widgets:
      - button:
          #x: 150
          #y: 150
          #width: 100
          #height: 100
          checkable: false
          align: center
          widgets:
            - label:
                align: center
                text: "Relay_S2"
          on_release:
            then:
              - switch.toggle: relay_s2
    - id: settings
      widgets:
        - label:
            text: Display Brightness
        - slider:
            x: 50
            y: 100
            width: 220
            height: 30
            pad_all: 8
            min_value: 30
            max_value: 100
            on_release:
              then:
                - light.turn_on:
                    id: display_backlight # ID of the to be controlled light source
                    brightness: !lambda 'return x / 100.0;'
  on_idle:
    then:
      - lvgl.pause:
number:
    optimistic: true
    initial_value: 20
    restore_value: true
    min_value: 1
    max_value: 180
    step: 5
    mode: box
Thnx for the input,
The waveshare screens seems to be pretty fairly priced. Actually I was already looking for the same idea with a guition display:
https://www.aliexpress.com/item/1005006729377800.html?spm=a2g0o.cart.0.0.280761d7NlRLZQ&mp=1&gatewayAdapt=
They are much cheaper, but I dont know if there’s a any difference in (build)quality.
Do you guys have any experience with the guition displays?
Yeah I knew but about IPS having something to do with the display itself. I already found out I had to invert the colors, but now with your comment I know why :slight_smile: and it also solves the IPS vs TN code riddle :slight_smile: thnx.
Please don’t post country-specific Aliexpress links! Clicking on that sets my Aliexpress cookies to Dutch and I have to manually change it back.
I have used some Guition displays, no complaints. Not that specific one AFAIK.
I don’t see anything particularly wrong from the log output. The banding in the image is probably because the source image has limited colour depth - no obvious reason for your config to mess it up.
Oops. That’s the funny fact of AliExpress, I constantly needs to change my language to english in my account. Everytime I come back, I’t set back to my native language (Dutch) :-(.
But actually I knew this, so gotta pay attentio to it. I replaced the link in the original post.
Good to hear there are no complains about the Guition Display :+1:If I got one I’ll make sure my experience will find it’s way here :slight_smile:
Thnx I’ve looked into that one and but the image looks okay on my computer screen and also the gradient on the button which is generated by the LVGL component is also experiencing the same.
I resized another image to my displays resolution (480x320) and uploaded it to my config and turned off image resizing (to make sure the issue doesn’t rely in the resize feature of the Esphome’s Image component.
I guess there are no differences but this picture visualize the issue better than ever before.
This is the resized image I’ve set:
BackgroundNightWater480x320
and this is what it actually looks like on the display:
I also saw in the logs that Indeed as you said the ILI9488 uses 18bit and the color is set to 16 bit.
As I said earlier it looks like 8 bit graphics but perhaps I’m looking in the wrong direction as the logs state 16bit.
I slightly got a feeling I got an uncommon issue with my display (and I don’t like uncommon issues :blush:)
Could it be that my display is broken or something? Is there anyone else willing to test this on an ILI9488 with my yaml?
I’ve asked the reseller of the display about the SPI code (in all my desperateness I hoped it would led me to a solution). The reseller came back with several pieces of code. One of them seems like a partial solution to mimize the image banding:
But the code looks like some kind of Arduino code or so, I guess this should be done by the developer of esphome?
Ill paste the contents of the several txt files and their filenames below:
VCOM–uniformity of glow and burnout.txt
The most important parameter for setting the uniformity of glow and burnout is -VCOM.
The burnout does not disappear completely, but it becomes noticeably less.
writecommand(0xC5);
writedata(0x00);
writedata(0x4D); <--- !!!
writedata(0x80);
BOE3.5IPS-ILI9488和3.95inch一样.TXT
//************* Start Initial Sequence **********//
WriteComm(0xF7);
WriteData(0xA9);
WriteData(0x51);
WriteData(0X2C);
WriteData(0X82);
WriteComm(0xC0);
WriteData(0x0F);
WriteData(0x0f);
//VGH = 5*VCI   VGL = -3*VCI
WriteComm(0xC1);
WriteData(0x47);
WriteComm(0xC5);
WriteData(0x00);
WriteData(0x4D);
WriteData(0x80);
WriteComm(0xB1);
WriteData(0xB0);
WriteData(0X11);
//WriteComm(0xB1);
//WriteData(0xA0);
WriteComm(0xB4);
WriteData(0x02);
WriteComm(0x36);
WriteData(0x48);
WriteComm(0x3A);
WriteData(0x55);  //RGB565
WriteComm(0x21);
WriteData(0x00); //IPS
WriteComm(0xE9);
WriteData(0x00);
WriteComm(0xF7);
WriteData(0xA9);
WriteData(0x51);
WriteData(0x2C);
WriteData(0x82);
WriteComm(0xE0);
WriteData(0x00);
WriteData(0x07);
WriteData(0x0B);
WriteData(0x03);
WriteData(0x0F);
WriteData(0x05);
WriteData(0x30);
WriteData(0x56);
WriteData(0x47);
WriteData(0x04);
WriteData(0x0B);
WriteData(0x0A);
WriteData(0x2D);
WriteData(0x37);
WriteData(0x0F);
WriteComm(0xE1);
WriteData(0x00);
WriteData(0x0E);
WriteData(0x13);
WriteData(0x04);
WriteData(0x11);
WriteData(0x07);
WriteData(0x39);
WriteData(0x45);
WriteData(0x50);
WriteData(0x07);
WriteData(0x10);
WriteData(0x0D);
WriteData(0x32);
WriteData(0x36);
WriteData(0x0F);
WriteComm(0x11);
Delay(480);
WriteComm(0x29);
invert the colors.txt (i’m sure this is already done by the Display component invert-colors: true)
It is also important to invert the colors, but it is simple, anyone can do it.
writecommand (0x21);
writecommand(0xC5);
writedata(0x00);
writedata(0x4D); //  <--- important!!! -VCOM = -0.79688V
writedata(0x80);
writecommand (0x21); //inverse colors for IPS
chris day 发的IPS 代码.txt
 tft.writecommand(0xF7); // Adjust Control 3 (F7h)
     tft.writedata(0xA9);
     tft.writedata(0x51);
     tft.writedata(0X2C);
     tft.writedata(0X82);
     tft.writecommand(0xC0); // Power Control 1 (C0h)
     tft.writedata(0x0F);
     tft.writedata(0x0f);
     tft.writecommand(0xC1); // Power Control 2 (C1h)  //VGH = 5*VCI
VGL = -3*VCI
     tft.writedata(0x47);
     tft.writecommand(0xC5); // VCOM Control (C5h)
     tft.writedata(0x00);
     tft.writedata(0x4D);
     tft.writedata(0x80);
     tft.writecommand(0xB1); // Frame Rate Control (In Normal Mode/Full
Colors) (B1h)
     tft.writedata(0xB0);
     tft.writedata(0X11);
     tft.writecommand(0xB4); // Display Inversion Control (B4h)
     tft.writedata(0x02);
     tft.writecommand(0x21); // Display Inversion ON (21h)
     tft.writedata(0x00);    // IPS
     tft.writedata(0x2C);
     tft.writedata(0x82);
     tft.writecommand(0xE0); // PGAMCTRL (Positive Gamma Control) (E0h)
     tft.writedata(0x07);
     tft.writedata(0x0B);
     tft.writedata(0x03);
     tft.writedata(0x05);
     tft.writedata(0x30);
     tft.writedata(0x56);
     tft.writedata(0x04);
     tft.writedata(0x0A);
     tft.writedata(0x2D);
     tft.writedata(0x37);
     tft.writecommand(0xE1); // NGAMCTRL (Negative Gamma Control) (E1h)
     tft.writedata(0x0E);
     tft.writedata(0x13);
     tft.writedata(0x11);
     tft.writedata(0x39);
     tft.writedata(0x45);
     tft.writedata(0x50);
     tft.writedata(0x10);
     tft.writedata(0x0D);
     tft.writedata(0x32);
     tft.writedata(0x36);
I understand what they want but I believe I cannot perform the changes as this needs to be done in the template of the ILI9488_A driver model right?
I still hope someone is able to tell me what to do to solve this.
You can add additional init commands in YAML. Quote from “ILI9xxx TFT LCD Series — ESPHome”
Thanks again for your input I saw that section but didn’t recognized it as this was the way to put that coe :slight_smile:
I tried and partly suceeded as not all code was accepted when uploading.
Of course the part of color inversing and other stufff that already got done by the display component wasn’t necessary and I left that away.
I tried every with this piece of code:
writecommand(0xC5);
writedata(0x00);
writedata(0x80);
I could succesfully upload it but it didn’t solved the issue, it actually didn’t changed anything.
In the end I tried as far as I know everything possible and with your help even more and I still couldn’t solve the image burnout/banding. So I decided to return the device and buy another one with another display driver.
At first I wanted to buy a guition ESP32-S3 display but I turned Ali inside/out and discovered that there simply isn’t a guition 3.5" or 4.3" display that runs an ESPHOME compatible display driver.
To be honest I find it pretty hard to find a suitable display for ESPHome. I really like ESPHome but it would be great if drivers that are used by Guition were also supported like:
St7262
ST3401A
AXS15231B
Thank you all very much for your input (very very appreciated), up to the next one :wink:
This is a nice display, fully supported. https://www.waveshare.com/esp32-s3-touch-lcd-4.3.htm
The AXS15231B driver chip is also supported.
