firstly, yes, there is an apex charts sub thread however with over 4,000 posts on there I fear anything I do will just get lost in the swarm and it’s hard to maintain a conversation. furthermore I don’t think my issue is apex charts related It’s more of an awareness of how to use it and the concepts of charting which I’m not very good at.
issue I have is that I have Four series data.
Three of them are temperature related in the house so they are within the range of say 15 to 25°C through the day
The fourth series is water temperature through radiators which can range from 0 or pretty low, to 70.
my apex chart for the 2 series plots fine but when I add the third - the radiator temperature - the other two series become pretty much straight lines and are skewed on the scale.
I don’t know what this phenomenon is called and I don’t know how to fix it.
Any ideas please
I have attached the chart with the three working series .
I’d like to add the radiator temperature to this but it ranges from 0 to 70 which more or less makes these three lines pretty much flat on there about on the y axis
Thankyou, I googled that and got it so work.
But
Any idea why my right hand Yaxis title “LWT” is not being displayed? I’ve got no errors on the yaml below.
type: custom:apexcharts-card
header:
show: true
title: Max Soft Bounds + Min Fixed Bound
graph_span: 20min
series:
- entity: sensor.random0_100
yaxis: # only 1 yaxis, no need for id or yaxis_id
- min: 0
# if the sensor doesn't go above 50, the max of the axis will be 50
# else the max will be the maximum value of the sensor
max: ~50
decimals: 0
apex_config:
tickAmount: 4
So you still have apex_config, but don’t have yaxis (again):
After you gave up on me I approached a completely different forum unrelated to home assistant where I was able to elicit most helpful replies with examples and even a bit of tutoring what more could one want Kind people I will unsubscribe from this post so unfortunately I Will be unable to bear witness to subsequent replies
