Display entities in a row with separator
Hi all,
I’m breaking my head over this.
A Modbus slave is having 6 registers which contain year, month, day, hour, minute, second.
I want to show these in a card like:
25-12-2024
10:40:30
So far i’m only able to show it like:
(‘25’, ‘12’, ‘2024’)
(‘10’, ‘40’, ‘30’)
with the help of a template:
  sensors:
    date_magnum_heating:
      value_template: "{{states('sensor.magnum_day'), states('sensor.magnum_month'), states('sensor.magnum_year')}}"
  sensors:
    time_magnum_heating:
      value_template: "{{states('sensor.magnum_hour'), states('sensor.magnum_minute'), states('sensor.magnum_second')}}"
I have no idea how to format it or how to just place the entities in a row with a “-” and “:” separator like:
sensor.magnum_day-magnum-sensor.magnum_month-sensor.magnum_year
sensor.magnum_hour:sensor.magnum_minute:sensor.magnum_second
Any help will be appreciated.
EDIT:
With the solution @atlflyer provided i’ve created a sensor with some formatting if date or time includes a single digit like: H:M:S 1:2:3 will be 01:02:03
    sensors:
        value_template: "{{ '%0.2d' % states('sensor.magnum_day')|int }}-{{ '%0.2d' % states('sensor.magnum_month')|int }}-{{ '%0.4d' % states('sensor.magnum_year')|int }}"
    sensors:
        value_template: "{{ '%0.2d' % states('sensor.magnum_hour')|int }}:{{ '%0.2d' % states('sensor.magnum_minute')|int }}:{{ '%0.2d' % states('sensor.magnum_second')|int }}"
This might be something: GitHub - benct/lovelace-multiple-entity-row: Show multiple entity states and attributes on entity rows in Home Assistant's Lovelace UI
But “name: false” or “name: Day” doesn’t work for entities under: "type: custom: multiple-entity-row. They just disappear after saving.
type: entities
entities:
  - entity: sensor.date_magnum_heating
    show_state: false
    icon: mdi:calendar
    type: custom:multiple-entity-row
    entities:
      - sensor.magnum_day
        name: Day #<- disappears.
      - sensor.magnum_month
      - sensor.magnum_year
And how to align the values and put a “-” or “:” between them?
When posting YAML, please be sure to follow the formatting guidance in this post. You should also consider using the new format for template sensor config instead of the retired legacy format.
You can mix templates with dynamic content (inside the curly brackets) with static content (outside), like so:
template:
  - sensor:
    - name: Date Magnum Heating
      state: >
        {{states(‘sensor.magnum_day’)}}-{{states(‘sensor.magnum_month’)}}-{{states(‘sensor.magnum_year’)}}
Yes, that works, thank you @atlflyer.
For now i converted it to the old template style.
I will look into the new style.
Thanks again.
