Display (Fully Kiosk) Component no longer available?
Hey,
I just upgraded to the latest 0.95.4 version and I see that the configuration checker no longer like my display component, which I’ve been using for my Fully Kiosk Units.
Is the component no longer available?
Here is the error I get (have tried removing the attributes):
Invalid config for [display]: [host] is an invalid option for [display]. Check: display->host. (See ?, line ?). Please check the docs at https://home-assistant.io/components/display/
EDIT: I was upgrading from 0.94.2, so could have happened before the latest release of course.
Thanks…
Displays is a custom component and not part of the core:
You are so right.
Must be the heat here - I completely forgot that part :blush:
