Hello community,
I am using aqara button WXKG11LM with zigbee2mqtt.
I would like to display on a badge or in a card the last time the button was clicked (any click type).
Does anyone have a suggestion?
Thanks in advance!
Hello community,
Thanks in advance!
Does this button create an entity? If so, does the entity have an attribute for when it was last pressed? If so, you can create a template sensor to capture that time as its state, or use a method (probably custom card or row) to display secondary info.
If not, I assume it creates an event when itâs pressed? If so, youâd need to create an automation to capture the current time ânow()â as the state of a template sensor.
Basically Iâd like to get the information âIl y a 1 heureâ (FR) below (screen shot from the journal) in a markdown card or in a badge
Preferably without adding automation or a new sensor. I believe that it is possible as the journal is displaying it.
OK, can you take a screenshot of the entity attributes in developer tools -> states?
It doesnât contain time related attribute, but I was hoping I could get the information from the journal for instance
Have you tried something like this:
{{ relative_time(states.sensor.0x00158....last_changed | timestamp_local) }}
Works only if recorder is enabled for this entity.
Next you might need to run an update automation - something like this:
- id: 'update_template_sensors'
alias: Update Template Sensors
description: ''
- platform: time_pattern
seconds: /2
- data:
entity_id:
- sensor.t_motion_1
service: homeassistant.update_entity
This should help you get started. Paste this template into the Template Editor and it should report how long ago the sensor was updated (hours:minutes:seconds).
{{ (now().timestamp() - states.sensor.0x00158d00027bf7f5_click.last_updated.timestamp()) | timestamp_custom('%H:%M:%S', False) }}
- entities:
- entity: binary_sensor.porte
secondary_info: last-changed
should display what youâre looking for.
I had the impression the requirement was to display only the âlast time changedâ value. Nevertheless, your solution is the easiest way to get the job done.
indeed simple way to display it
Thanks!
I got this working as well, with the [ââ] as my sensor name starts with a number, home-assistant wouldnât allow your suggested syntax
Thanks for the lead anyway!
{{ (as_timestamp(now()) - as_timestamp(states.sensor['0x00158d00027bf7f5_click'].last_changed)) | timestamp_custom('%H:%M:%S', False) }}
Thank You!
Can you please explain to me what âFalseâ is doing ?
The second option determines if the time should be displayed as-is or converted to local time (the default is True which converts it to local time).
Filter
timestamp_custom(format_string, local_time=True)
converts an UNIX timestamp to its string representation based on a custom format, the use of a local timezone is default. Supports the standard Python time formatting options.
Sorry to re-open this thread but seemed like a relevant place to ask a follow-up question: Is there any way to get the actual last state change time that survives a home assistant re-start?
When I look at the historical value of the state I can see the actual times so I am hoping there is a way to retrieve it from the recorded values.
