I use the following code extract on a dashboard, but instead of the IP states('sensor.myip)
I would like to show the ISP name e.g. any IP prefixed with 145 (145.x.x.x) should show “Starlink” and anything else is ISP B? I have tried various ways, but can’t figure it out? I thought it should be as simple as manipulating a string?
type: custom:vertical-stack-in-card
mode: horizontal
square: false
columns: 1
cards:
primary: Internet ({{states('sensor.myip') }})
icon: mdi:web
icon_color: blue
layout: horizontal
secondary: >-
{{states('sensor.speedtest_download') }} Mbit/s |
{{states('sensor.speedtest_upload') }} Mbit/s |
{{states('sensor.speedtest_ping') }} ms |
{{relative_time(states.sensor.speedtest_download.last_updated) }} ago
- square: false
Think this might work, template works but not sure how the mushroom card works
mode: horizontal
square: false
columns: 1
cards:
primary: Internet ({% if states('sensor.myip').startswith("145") %} Starlink {% else %} ISP B {% endif %}
icon: mdi:web
icon_color: blue
layout: horizontal
secondary: >-
- square: false
Thank you, works perfectly - another one to file carefully away Always learning…
shirasp
(Shira)
August 22, 2022, 5:09pm
4
This is a really cool idea! Mind sharing your full code with the graphs as well?
Also, how did you discover that the prefix is associated with a specific ISP?
Sure, the ISP IP address will show in your router.
mode: horizontal
square: false
columns: 1
cards:
primary: >-
Internet ({% if states('sensor.myip').startswith("145") %}Starlink) {%
else %} Boundless) {% endif %}
icon: mdi:web
icon_color: blue
layout: horizontal
secondary: >-
- square: false
columns: 1
type: grid
cards:
- type: custom:vertical-stack-in-card
horizontal: true
cards:
secondary: Starlink
entity: switch.starlink
layout: vertical
tap_action:
action: toggle
icon: |-
{% if is_state('switch.starlink', 'on') %}
mdi:power-plug
{% else %}
mdi:power-plug-outline
{% endif %}
icon_color: |-
green
{% else %}
red
{% endif %}
- type: custom:mini-graph-card
entities:
- sensor.speedtest_download
line_color: blue
line_width: 8
font_size: 75
entities:
- sensor.speedtest_upload
show:
icon: true
label: false
state: true
hours_to_show: 24
line_color: '#e74c3c'
line_width: 8
font_size: 75
shirasp
(Shira)
August 22, 2022, 5:47pm
6
Thanks for the quick reply! So the graph part is the second “square: false” and the 2 lines under it?
When I tried that code, I got an error for invalid configuration
Ive just updated the post - full code now posted…
If you wanted to extend this further, you could pass your sensor.myip
into an api such as API Documentation - ipapi to be able to lookup the registered ISP against your IP.
