I measure several temps in HA and use them in node-red for various functions and generate an average temp value. I store this an a global variable.
I would like to display this in HAin a badge for the states menu or a guage in the Lovelace.
I have been playing with using an Input number but have been having an issue trying to set that value using a call service node. I have something wrong with it if it should work as I cant get it right.
So if the above method is the only way to do it could someone give me an example or if there is a better way I would like to see that please.
I was also thinking mqtt but would love to see other options
The options you mentioned are the ones I generally use. If number doesn’t work for you try input_text. You can convert it to a float or int in jinja using the template sensor.
I’m using the HA API to create a new entity. In Node-RED, I use a call service node using HTTP and do a POST. No need to set this up ahead of time; the POST will create the entity. In my case, I’m setting the value of my electric meter so that I can display it in Lovelace.
I ended up installing a mqtt broker on my linux server to get my camera info into HA so used mqtt and a node to inject the info I needed. It seems to work really well. Thanks for the help
