But that’s exactly the URLs I am using within my configuration - I honestly don’t know what went wrong?
You can download my updated NodeRED flow + lovelace data:
https://www.vseznalec.si/homeassistant/OilFox/
Username:
homeassistant
Password:
virtualclone2020_weeWX%
In flow just change MAIL and PASSWORD to your login data and you should be up and running.
In case that you need to install any node on importing flow - just do it (confirm it).
Hi kslb,
Small question, i have installed Node-Red and also imported your data.
I changed also my login data.
But after my first try to run I get some errors, see screenshot!
Any idea?
regards,
Jurgen
You should install missing components in NodeRed…
Hi kslb,
what are they?
I’m using:
Install all this (missing ones) and flow should probably start working. It is intresting that on importing you did not get any info regarding missing components, because last time when I import flow I got info which components were missing…
Sorry for the delay, oilfox is working fine now!
Last question, do you have create a card with daily or weekly consumption?
Because I have build a daily consumption card with utility_meter, but my results are 0.
Is this because we have only one measurement per day?
Regards,
Jurgen
I’m using only the cards as shown in previous posts.
Which card is that which are you using…
Show me the lovelace code and I will try to use it and fix it…
Hi kslb,
Here my configuration.yaml code for the utility_meter.
utility_meter:
daily_energy:
source: sensor.shelly_shplg_s_b52b76_total_consumption
cycle: daily
monthly_energy:
cycle: monthly
daily_energy_vaatwasser:
source: sensor.shelly_shplg_s_e18b0f_total_consumption
cycle: daily
monthly_energy_vaatwasser:
cycle: monthly
### Mazout
daily_mazout:
source: sensor.oilfox_trenutni_nivo_olja
cycle: daily
weekly_mazout:
cycle: weekly
monthly_mazout:
cycle: monthly
yearly_mazout:
cycle: yearly
And here my card code!
type: horizontal-stack
title: Stookolie
cards:
- type: entities
entities:
- entity: sensor.oilfox_trenutni_nivo_olja
- entity: sensor.daily_mazout
icon: 'mdi:hydraulic-oil-level'
- entity: sensor.weekly_mazout
- entity: sensor.oilfox_stopnja_napolnjenosti
- entity: sensor.oilfox_visina_nivo_olja
icon: 'mdi:counter'
- entity: sensor.oilfox_stanje_baterije
name: Batterij Meetsonde
state_color: true
font_size: 1em
gauge:
animatedValue: true
borders: true
colorNumbers: '#ccc'
colorPlate: ''
colorTitle: '#f5f5f5'
colorUnits: '#f5f5f5'
height: 240
highlights:
- color: brown
to: 600
- color: orange
to: 1200
- color: green
to: 3000
majorTicks:
- '0'
- '300'
- '600'
- '900'
- '1200'
- '1500'
- '1800'
- '2100'
- '2400'
- '2700'
- '3000'
maxValue: 3000
minValue: 0
minorTicks: 10
startAngle: 45
strokeTicks: true
sticksAngle: 270
units: (L)
type: radial-gauge
valueBox: true
valueDec: 1
valueInt: 2
width: 230
type: 'custom:canvas-gauge-card'
font_size: 1em
gauge:
animatedValue: true
borders: true
colorPlate: ''
height: 240
highlights:
- color: brown
to: 30
- color: orange
to: 40
- color: green
to: 100
majorTicks:
- '0'
- '10'
- '20'
- '30'
- '40'
- '50'
- '60'
- '70'
- '80'
- '90'
- '100'
maxValue: 100
minValue: 0
minorTicks: 10
startAngle: 45
strokeTicks: true
sticksAngle: 270
units: (%)
type: radial-gauge
valueBox: true
valueDec: 1
valueInt: 2
width: 230
font_size: 1em
gauge:
animatedValue: true
borders: true
colorPlate: ''
height: 240
highlights:
- color: gray
to: 100
majorTicks:
- '0'
- '10'
- '20'
- '30'
- '40'
- '50'
- '60'
- '70'
- '80'
- '90'
- '100'
maxValue: 100
minValue: 0
minorTicks: 10
startAngle: 45
strokeTicks: true
sticksAngle: 270
units: (cm)
type: radial-gauge
valueBox: true
valueDec: 1
valueInt: 2
width: 230
Thx,
Jurgen
FWIW - I could get the curl only working via:
token=`curl --silent -d '{"email":"EMAIL","password":"PASSWORD"}' -k 'https://api.oilfox.io/v3/login' -X POST -H 'Content-Type: application/json' | sed "s/{.*\"access_token\":\"\([^\"]*\).*}/\1/g"`;curl -H "Authorization: Bearer $token" -H "Connection: Keep-Alive" -H "User-Agent: HomeAssistant" -H "Content-Type: application/json" https://api.oilfox.io/v4/summary
How are the queries done in FLUX?
thanks for your work I’ve been using the workflow for 2 weeks but now I think they changed the Oilfox API: customer-api/docs/v1 at main · foxinsights/customer-api · GitHub
I’ve adjusted your workflow, it should work again now:
(Change
in “Login” → user, pw
and
in “Get Summary” → device-number (-> see Oilfox-App):
Also you need this node: node-red-contrib-http-request (node) - Node-RED
[{"id":"3079ee36.02c2d2","type":"tab","label":"Oilfox","disabled":false,"info":""},{"id":"a211bae9.c4bc88","type":"change","z":"3079ee36.02c2d2","name":"Befehl: Tokenabruf ","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"email\":\"xxxx\",\"password\":\"xxxxx\"}","tot":"json"},{"t":"set","p":"headers","pt":"msg","to":"{\"Content-Type\":\"application/json\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":40,"wires":[["a8d341648efcb13b"]]},{"id":"c376eaa0f7c9dc9f","type":"debug","z":"3079ee36.02c2d2","name":"curl","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":40,"wires":[]},{"id":"e26c9ba4042d6762","type":"json","z":"3079ee36.02c2d2","name":"Token parsing","property":"payload","action":"","pretty":true,"x":140,"y":120,"wires":[["be5e9539112e31bc"]]},{"id":"4d3699a8c494fd22","type":"debug","z":"3079ee36.02c2d2","name":"Token","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":120,"wires":[]},{"id":"be5e9539112e31bc","type":"change","z":"3079ee36.02c2d2","name":"Headers & Auth","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\t \"Authorization\" : payload.token_type & \" \" & payload.access_token,\t \"Content-Type\" : \"application/json\"\t}","tot":"jsonata"},{"t":"delete","p":"payload","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":120,"wires":[["4d3699a8c494fd22","7a4956b43451d665"]]},{"id":"e90d148f71e213d8","type":"debug","z":"3079ee36.02c2d2","name":"Summary","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":860,"y":180,"wires":[]},{"id":"596c4fad6ca9bae1","type":"json","z":"3079ee36.02c2d2","name":"Summary parsing","property":"payload","action":"","pretty":true,"x":410,"y":180,"wires":[["e90d148f71e213d8","70ee284899ec8fbf","ec1a249b0e7cfca4"]]},{"id":"70ee284899ec8fbf","type":"ha-entity","z":"3079ee36.02c2d2","name":"OilFox Fill Percentage","server":"fbb2f3e2.d6216","version":2,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"OilFox Fill Percentage"},{"property":"device_class","value":"mdi:oil-level"},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"%"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"state":"payload.fillLevelPercent","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":640,"y":240,"wires":[["c952810034ee570c"]]},{"id":"c952810034ee570c","type":"debug","z":"3079ee36.02c2d2","name":"Entity Percent","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":880,"y":260,"wires":[]},{"id":"ec1a249b0e7cfca4","type":"ha-entity","z":"3079ee36.02c2d2","name":"OilFox_Fuellstand_heute","server":"fbb2f3e2.d6216","version":2,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"oilfox_fuellstand_heute"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":"l"},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"state":"payload.fillLevelQuantity","stateType":"msg","attributes":[{"property":"letzteMessung","value":"payload.currentMeteringAt","valueType":"msg"},{"property":"naechsteMessung","value":"payload.nextMeteringAt","valueType":"msg"},{"property":"battery","value":"payload.batteryLevel","valueType":"msg"},{"property":"unit","value":"payload.quantityUnit","valueType":"msg"},{"property":"daysReach","value":"payload.daysReach","valueType":"msg"}],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":650,"y":320,"wires":[["b828611b0ad5db4d"]]},{"id":"b828611b0ad5db4d","type":"debug","z":"3079ee36.02c2d2","name":"Entity Liters","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":870,"y":320,"wires":[]},{"id":"2852886dd0231d1a","type":"inject","z":"3079ee36.02c2d2","name":"00:05 Uhr","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"05 00 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":40,"wires":[["a211bae9.c4bc88"]]},{"id":"a8d341648efcb13b","type":"www-request","z":"3079ee36.02c2d2","name":"Login","method":"POST","ret":"txt","url":"https://api.oilfox.io/customer-api/v1/login","follow-redirects":true,"persistent-http":true,"tls":"","x":620,"y":40,"wires":[["c376eaa0f7c9dc9f","e26c9ba4042d6762"]]},{"id":"7a4956b43451d665","type":"www-request","z":"3079ee36.02c2d2","name":"Get Summary","method":"GET","ret":"txt","url":"https://api.oilfox.io/customer-api/v1/device/[xxxx]","follow-redirects":true,"persistent-http":true,"tls":"","x":140,"y":180,"wires":[["596c4fad6ca9bae1"]]},{"id":"fbb2f3e2.d6216","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
credits also goes to: Get Your Personal Oil Well Level – Integrating OilFox Into Home Assistant using node-red – MolesBlog
Any idea how to fix that?
Did you use the flow I posted?
Did you change the device ID in “Get Summary” (URL: https://api.oilfox.io/customer-api/v1/device/[xxxx])?
Eh… sorry… I made a mistake… at device ID I wrote [ID], now I wrote withouth [ ] and it’s working…
But how to get data “battery level”, “oil level high” to home assistant…
I only get “oil level %” and “oil level L”
In the screenshot you can see that I created the values from the API as attributes. If you want to have them as states, you have to e.g. copy and adjust the “OilFox Fill Percentage” node:
I also looked for the “oil level high” but the API doesn’t provide it:
hwid | string | Hardware ID of the device |
currentMeteringAt | string | RFC3339 timestamp |
nextMeteringAt | string | RFC3339 timestamp |
daysReach | int, optional | estimated days until the storage runs empty |
validationError | string, optional | enum with errors regarding the measurement, see below |
batteryLevel | string, optional | enum of the battery level, see below |
fillLevelPercent | int, optional | fill level in %, 0-100 |
fillLevelQuantity | int, optional | fill level in kg or L |
quantityUnit | string | unit of the fill level: kg or L |
So, I think you have to calculate the hight like this (the hight of my tank is 119cm):
{% set t = states(‘sensor.oilfox_fill_percentage’) | int %}
{{ (t * 119) / 100 }}
put this tamplate to your configuration yaml:
template
- sensor:
- name: "oilfox_hight_level"
state:
"{% set t = states('sensor.oilfox_fill_percentage') | int %}
{{ (t * 119) / 100 }}"
unit_of_measurement: "cm"
unique_id: "12345678998765"
the API-version before was not official!
now it is
Great… so this will be probably more pernament solution…
Thank you for everything…
Hi guy’s,
After the last HA update my Oilfox Node Red is not working anymore.
Can somebody maybe share his Node Red config again?
And steps to taken to get it running?
Jurgen
