I think Remote Admin is a PLUS feature, you need to get a paid licence for this
I already have a paid licence…
Hi @daemondazz , I’ve just created a PR on your Github repo that adds support for screensaver control (useful when using Fully Kiosk in combination with an Amazon Fire tablet) and text-to-speech support. Hope you find it useful
I am using your version and TTS and the screensaver on/off works great! Thank you.
This is great, thanks for the work.
I just installed Fully Kiosk on a tablet and I am using it always on to control HA.
I like the motion activation of the screen, though it only works at a fairly close distance. I will also test the sound activation. Also looking forward to giving TTS a go.
I’m using an automation like @myle’s to keep the battery level between 30 and 80%.
I am also using the generic camera component. I don’t know if this is the best way to do it. It is working in the sense that I see some images, but I don’t understand if I can control the update interval of the image and its size:
camera:
- platform: generic
still_image_url: http://tablet_ip:2323/?cmd=getCamshot&password=fully_password
I’m using the latest version and still can’t use the TTS feature…
Can someone help? An example on how to use?
Hi
I know this is an older component but i have been using for some time to monitor battery on a wall tablet and its been working great
I just updated to 0.88 and i now get an error
Integrations need to be in their own folder. Change display/fully_kiosk.py to fully_kiosk/display.py. This will stop working soon.
thanks
hey @lerroy_b,
yes, this is related to some changes in the dev side. you can find this here: https://developers.home-assistant.io/blog/2019/02/19/the-great-migration.html
I think the change should be done both in the path to the config and the component itself. This is how I understand the change.
hope this helps!
I have raised this as an issue on github: Issues with version 88.1 · Issue #7 · daemondazz/homeassistant-displays · GitHub
as follows:
Home Assistant release with the issue:
0.88.1
Last working Home Assistant release (if known):
0.87
Operating environment (Hass.io/Docker/Windows/etc.):
Hass.io
Component/platform:
https://www.home-assistant.io/custom_components/display/fully_kiosk
Description of problem:
As of 0.88.1 a warning is shown:
Your configuration contains extra keys that the platform does not support (but were silently accepted before 0.88). Please find and remove the following.This will become a breaking change.
- [name], [host], [password]. (See /config/configuration.yaml, line 70).
- [name], [host], [password]. (See /config/configuration.yaml, line 74).
- [name], [host], [password]. (See /config/configuration.yaml, line 78).
- [name], [host], [password]. (See /config/configuration.yaml, line 82).
Problem-relevant configuration.yaml
entries and (fill out even if it seems unimportant):
#tablet battery
display:
- platform: fully_kiosk
host: '192.168.0.179'
password: !secret http_password
host: '192.168.0.168'
host: '192.168.0.185'
name: 'Nexus 10 Tablet'
host: '192.168.0.183'
I have started a new thread relating to the above issue here:
I have created a Pull Request to fix this issue for HA 0.88+. Do give it a spin!
Once this PR is reviewed and merged by @daemondazz then this platform should be compatible with future Home Assistant versions.
I’ve pushed some changes that fixes async problems with the display component and fully_kiosk platform and also have done a bit of a refactor to simplify things a bit.
Please note the names of some of the services have changed, so check the README file out for details.
Thanks for this component !
I installed it on HA 0.93 and it works perfectly for my Archos Hello 10 tablet.
Wanted to use this for a tablet and HA, but I have the custom compact header installed which needs javascript. How do you enable javascript in the Fully Kiosk browser? I looked through all the settings but don’t seem to be able to find it. Is there something special I need to do?
Works brilliand on 0.94.0 so far.
One questoin though: How do you “call” an URL?
automation:
- alias: '[Kitcehen] Turn On'
platform: state
entity_id: binary_sensor.motion_sensor_xxxxxxxxxxxxx
to: 'on'
- service: display.turn_on
entity_id: display.kitchen_tablet
- delay:
seconds: 2
- service: fully_kiosk.screensaver_stop
- delay:
seconds: 2
- service: display.load_url
url: http://xxx.xxx.xxx.xxx:8123/lovelace/1
But I don’t think the ‘data’ part is correct - well it doesn’t work
EDIT: Well actyally that did work .
For some reason I had to reboot my Tablet and then it worked.
Hey man,
Just letting you know you did an awesome job with this one. It took me a few hours to get it setup, didn’t know the ‘#’ in the secrets.yaml would cause it to comment out the password. If possible could you add some states in your documentation on how to pull those I had to go through the comments to check it but in the end I managed to get it working.
Thanks!
Hey guys,
I ran through the breaking changes of the 104 and 104.1 update, but couldn’t find anything regarding this.
But after the upgrade I get that the integration was not set up?
What did I miss?
EDIT: Missed the _init_py file update that was fixed along with the 104 update.
Thanks!
Yep, 0.104 removed the groups.all_xxx
entities, so had to remove the setup for that.
Hey, what’s the news on this component since HACS? I was using it to turn off the screensaver on my kindle tablets when a person was detected outside to bring up the camera feed… But since I moved to HACS, I lost this component and am not able to add it as a custom component… Any chance of bringing it up to date?
Going to answer my question as it doesn’t seem like this will make it into HACS and others might be forced to move off this component when they go to HACS too. I ended up implementing the screensaver functionality just with a shell command integration by adding this to my configuration.yaml:
shell_command:
fully_kiosk_stop_screensaver: "/usr/bin/curl -X POST 'http://[YOUR_FULLY_KIOSK_IP]:2323/?cmd=stopScreensaver&type=json&password=[FULLY_KIOSK_PASSWORD]'"
You can actually replicate more or less all of the functionality of this component in similar ways. There are some good guides to get you started here, here, and here. It’s also worth noting that this does work on homeassistant supervised (formerly hass.io), at least for me.
