i get the following when i restart HA. what i should I do?
What command would I send to control the brightness?
Use this:
http://your.tablet.ip.address:2323/?cmd=setStringSetting&key=screenBrightness&value=1&type=json&password=your_password
got this from here:
This has seemed to stop working with the latest HA update.
Running the following version:
Home Assistant OS 5.13
Core 2021.6.1
Supervisor 2021.05.4
I have not changed anything in the YAML.
it has always been:
display:
- platform: fully_kiosk
host: '192.168.0.179'
password: !secret http_password
since the update it will not let me reboot unless i remove the above from the YAML.
it comes back and says:
[2743349152] The system cannot restart because the configuration is not valid: Component error: display - Integration 'display' not found.
11:50:46 – (ERROR) Home Assistant WebSocket API
11:50:46 – (ERROR) Home Assistant Supervisor
anyone else had any issues?
Same issue here with the June updates. I ended up having to comment out the display platform to be able to reboot, but as a result lost all functionality.
Same issue here. Got config error and had to comment out to get back up and running.
Saw you were having the same issue as I was. And discovered that @GuruPG opened an issue on GitHub. Seems to be resolved, haven’t tested as yet personally. Thought you’d like to know.
https://github.com/daemondazz/homeassistant-displays/issues/24
Update 6/8: Confirmed it works now with the updated build. Did have to edit the manifest.json to read “display” instead of “displays” though.
