Display sensor data on 1.54" ePaper price tags
Display sensor data and graphs on 1.54" ePaper display tags, the kind that is commonly used as price tags in stores:
This blueprint is meant for use with the OpenEPaperLink integration by Jonas Niesner. You can use it to display and periodically update various sensor data on ePaper tags, such as the common 1.54" ST‐GR16000 price tags.
What you need
  1. A price tag running the OpenEPaperLink custom firmware
  2. An OpenEPaperLink access point that you can build yourself or buy from places like this Tindie store.
  3. The OpenEPaperLink integration running on your HA instance.
What the blueprint does
The blueprint puts together a call to open_epaper_link.drawcustom with formatting instructions to draw a new image with the data you want. You can then set up triggers so that the tag content gets updated periodically.
The 152x152 pixels of a 1.54" display don't give a lot of screen real estate to work with. The automation lets you show up to six values at the same time. Two numerical sensor values are shown at the top; each of them can be displayed in red if it is above and/or below a certain threshold. Two line graphs are shown in the middle and at the bottom; each graph shows a black line with the values of a sensor over a past time period (by default 24h), and in addition the graph can display a second, thin red line with the values from a second sensor over the same time period.
Fonts and icons are customizable.
As usual, ePaper tags are slow, so this is best used for data that doesn't update all that often.
Blueprint
Github link
blueprint:
  name: OpenEPaperLink 1.54-inch Sensor Data Display
  description: 'Display sensor data and graphs on 1.54" ePaper display tags.
    [OpenEPaperLink integration](https://github.com/jonasniesner/open_epaper_link_homeassistant)
    by Jonas Niesner. With this, you can set up automations to use the common
    1.54" ST‐GR16000 price tags to display various sensor data.
    The display can show up to six values at the same time, in the following
    arrangement:
    * Two numerical sensor values at the top. By default these are shown in black.
    Each of them can be displayed in red if it is above and/or below a certain threshold.
    * Two line graphs in the middle and bottom. Each graph shows a black line
    with the values of a sensor over a past time period (by default 24h).
    In addition, the graph can display a thin red line with the values from a
  domain: automation
  input:
    tag_entity:
      description: >
        Data will be displayed on this ePaper tag. The blueprint assumes a
        1.54" tag with 152x152 pixels.
      selector:
        # Unfortunately we cannot use a `target` selector here, because
        # the OpenEPaperLink integration throws an error when calling `drawcustom`
        # with a `device_id`.
        entity:
          multiple: false
    triggers:
      name: When to initiate update
      description: >
        This will send new data to the access point. Keep in mind that the tags
        are refreshed only when they check in with the access point, so it may
        take some time until the display itself is updated.
      selector:
    sensor1:
      name: Top left - Sensor
      description: Values from this sensor will be displayed at the top left.
      selector:
        entity:
    field1_icon:
      name: Top left - Icon
      description: This icon will be displayed next to the data at the top left.
      selector:
        icon:
    field1_warn_above:
      name: Top left - Upper warning threshold
      description: Values above this number will be displayed in red.
      default: 1000
      selector:
        number:
          min: -100000000000.0
          max:  100000000000.0
          mode: box
          step: any
    field1_warn_below:
      name: Top left - Lower warning threshold
      description: Values below this number will be displayed in red.
      default: -1000
      selector:
        number:
          max:  100000000000.0
          mode: box
          step: any
    sensor2:
      name: Top right - Sensor
      description: Values from this sensor will be displayed at the top right.
      selector:
        entity:
    field2_icon:
      name: Top right - Icon
      description: This icon will be displayed next to the data at the top right.
      selector:
        icon:
    field2_warn_above:
      name: Top right - Upper warning threshold
      default: 1000
      selector:
        number:
          max:  100000000000.0
          mode: box
          step: any
    field2_warn_below:
      name: Top right - Lower warning threshold
      default: -1000
      selector:
        number:
          max:  100000000000.0
          mode: box
          step: any
    sensor3:
      name: Middle graph - Sensor
      description: Values from this sensor will be displayed as a black line in the middle graph.
      selector:
        entity:
    field3_icon:
      name: Middle graph - Icon
      description: This icon will be displayed next to the middle graph.
      selector:
        icon:
    field3_duration:
      name: Middle graph - Duration
      description: >
        Total duration (in seconds) of the data shown on the middle graph.
        The default is 86400 seconds (24 hours).
      default: 86400
      selector:
        number:
          min: 60
          max: 31622400 # 1 year (366 days)
          mode: box
          step: 1
          unit_of_measurement: seconds
    sensor4:
      name: Middle graph - Second sensor
      description: If a sensor is selected here, values will be displayed as a thin red line in the middle graph.
      default: ""
      selector:
        entity:
    sensor5:
      name: Bottom graph - Sensor
      description: Values from this sensor will be displayed as a black line in the bottom graph.
      selector:
        entity:
    field4_icon:
      name: Bottom graph - Icon
      description: This icon will be displayed next to the bottom graph.
      selector:
        icon:
    field4_duration:
      name: Bottom graph - Duration
      description: >
        Total duration (in seconds) of the data shown on the bottom graph.
      default: 86400
      selector:
        number:
          min: 60
          mode: box
          step: 1
    sensor6:
      name: Bottom graph - Second sensor
      description: If a sensor is selected here, values will be displayed as a thin red line in the bottom graph.
      default: ""
      selector:
        entity:
    font_data:
      name: Font - Data values
      description: >
        This font will be used to display the numerical data values.
        OpenEPaperLink has `ppb.ttf` and `rbm.ttf` built in.
        If you want custom fonts, upload them to `/media` on HA, then specify
        e.g. `/media/Bahnschrift.ttf`.
      default: ppb.ttf
    font_unit:
      name: Font - Units
      description: >
        This font will be used to display the units.
      default: ppb.ttf
    font_legend:
      name: Font - Graph legend
      description: >
        This font will be used to display the small legend next to the graphs.
      default: ppb.ttf
    frame_color:
      description: Optionally draw a red or black frame around each display.
      default: white
      selector:
        select:
          options:
            - white
            - red
            - black
          mode: dropdown
  !input triggers
condition: []
variables:
  tag: !input tag_entity
  field1_icon: !input field1_icon
  sensor1: !input sensor1
  field1_warn_above: !input field1_warn_above
  field1_warn_below: !input field1_warn_below
  field2_icon: !input field2_icon
  sensor2: !input sensor2
  field2_warn_above: !input field2_warn_above
  field2_warn_below: !input field2_warn_below
  field3_icon: !input field3_icon
  sensor3: !input sensor3
  field3_duration: !input field3_duration
  sensor4: !input sensor4
  field4_icon: !input field4_icon
  sensor5: !input sensor5
  field4_duration: !input field4_duration
  sensor6: !input sensor6
  font_data: !input font_data
  font_unit: !input font_unit
  font_legend: !input font_legend
  frame_color: !input frame_color
  # Some processing to get sensor data and coloring
  field1_value: "{{states(''''~sensor1)}}"
  field1_unit: "{{state_attr(''''~sensor1,'unit_of_measurement')}}"
  field2_value: "{{states(''''~sensor2)}}"
  field2_unit: "{{state_attr(''''~sensor2,'unit_of_measurement')}}"
  field1_color: >
    {% if is_number(float(field1_value,"")) and ((is_number(float(field1_warn_above,"")) and (float(field1_value) > float(field1_warn_above)))
                                              or (is_number(float(field1_warn_below,"")) and (float(field1_value) < float(field1_warn_below)))) -%}
    red
    {%- else -%}
    black
    {%- endif %}
  field2_color: >
    {% if is_number(float(field2_value,"")) and ((is_number(float(field2_warn_above,"")) and (float(field2_value) > float(field2_warn_above)))
                                              or (is_number(float(field2_warn_below,"")) and (float(field2_value) < float(field2_warn_below)))) -%}
    red
    {%- else -%}
    black
    {%- endif %}
  # Building blocks for the various UI components of the display
  building_blocks:
    - &frame
      type: rectangle
      outline: !input frame_color
      fill: white
      width: 1
    - &icon
      type: icon
      color: black
    - &value
      type: text
      font: !input font_data
      color: black
      anchor: mm
    - &unit
      type: text
      font: !input font_unit
      y_padding: 14
      color: black
      anchor: mm
    - &plot
      type: plot
      font: !input font_legend
      ylegend:
        position: right
        color: red
      yaxis: null
    # Top left value
    - &frame1
      <<: *frame
      x_start: 0
      y_start: 0
      x_end: 75
      y_end: 49
    - &icon1
      <<: *icon
      color: "{{ field1_color }}"
      value: !input field1_icon
      x: 1
      "y": 8
    - &value1
      <<: *value
      value: "{{ field1_value }}"
      x: 52
      "y": 14
    - &unit1
      <<: *unit
      value: "{{ field1_unit }}"
      x: 52
    # Top right value
    - &frame2
      <<: *frame
      x_start: 77
      y_start: 0
      x_end: 151
      y_end: 49
    - &icon2
      <<: *icon
      color: "{{ field2_color }}"
      value: !input field2_icon
      x: 77
      "y": 8
    - &value2
      <<: *value
      value: "{{ field2_value }}"
      x: 128
      "y": 14
    - &unit2
      <<: *unit
      value: "{{ field2_unit }}"
      x: 128
    # Middle graph
    - &frame3
      <<: *frame
      x_start: 0
      y_start: 51
      x_end: 151
      y_end: 100
    - &icon3
      <<: *icon
      x: 1
      "y": 59
      value: !input field3_icon
    # Version with one line
    - &plot3
      <<: *plot
      x_start: 34
      y_start: 52
      x_end: 149
      y_end: 99
        - entity: !input sensor3
          width: 3
          joint: curve
    # Version with two lines
    - &plot3_2
      <<: *plot3
          width: 3
          joint: curve
          color: black
        - entity: !input sensor4
          width: 1
          joint: curve
          color: red
    # Bottom graph
    - &frame4
      <<: *frame
      x_start: 0
      y_start: 102
      x_end: 151
      y_end: 151
    - &icon4
      <<: *icon
      x: 1
      "y": 110
      value: !input field4_icon
    - &plot4
      <<: *plot
      x_start: 34
      y_start: 103
      x_end: 149
      y_end: 150
        - entity: !input sensor5
          width: 3
          joint: curve
    - &plot4_2
      <<: *plot4
          width: 3
          joint: curve
          color: black
        - entity: !input sensor6
          width: 1
          joint: curve
          color: red
mode: single
  # Check whether the two graphs have 1 or 2 data sources each
  # Unfortunately we currently need 4 different code paths for this
  # Todo: check if the OpenEPaperLink integration's `Plot` payload of the
  # `drawcustom` service can be made to ignore entities with invalid
  # sensors, then we can pass just "None" or pass the same entity twice.
  - choose:
      - conditions:
          - condition: and
            conditions:
              - "{{ states(sensor4) not in ['unavailable', 'unknown', 'none'] }}"
              - "{{ states(sensor6)     in ['unavailable', 'unknown', 'none'] }}"
        alias: Draw tag, top graph with 2 sensors, bottom with 1 sensor
        sequence:
          - service: open_epaper_link.drawcustom
              entity_id: !input tag_entity
              background: white
              rotate: 0
              ttl: 300
              payload:
                - <<: *frame1
                - <<: *icon1
                - <<: *value1
                - <<: *unit1
                - <<: *frame2
                - <<: *icon2
                - <<: *value2
                - <<: *unit2
                - <<: *frame3
                - <<: *icon3
                - <<: *plot3_2
                - <<: *frame4
                - <<: *icon4
                - <<: *plot4
      - conditions:
          - condition: and
            conditions:
              - "{{ states(sensor4)     in ['unavailable', 'unknown', 'none'] }}"
              - "{{ states(sensor6) not in ['unavailable', 'unknown', 'none'] }}"
        alias: Draw tag, top graph with 1 sensor, bottom with 2 sensors
        sequence:
              background: white
              rotate: 0
              ttl: 300
              payload:
                - <<: *frame1
                - <<: *icon1
                - <<: *value1
                - <<: *unit1
                - <<: *frame2
                - <<: *icon2
                - <<: *value2
                - <<: *unit2
                - <<: *frame3
                - <<: *icon3
                - <<: *plot3
                - <<: *frame4
                - <<: *icon4
                - <<: *plot4_2
      - conditions:
          - condition: and
            conditions:
        alias: Top and bottom graphs with 2 sensors each
        sequence:
              background: white
              rotate: 0
              ttl: 300
              payload:
                - <<: *frame1
                - <<: *icon1
                - <<: *value1
                - <<: *unit1
                - <<: *frame2
                - <<: *icon2
                - <<: *value2
                - <<: *unit2
                - <<: *frame3
                - <<: *icon3
                - <<: *plot3_2
                - <<: *frame4
                - <<: *icon4
                - <<: *plot4_2
    default:
          background: white
          rotate: 0
          ttl: 300
          payload:
                - <<: *frame1
                - <<: *icon1
                - <<: *value1
                - <<: *unit1
                - <<: *frame2
                - <<: *icon2
                - <<: *value2
                - <<: *unit2
                - <<: *frame3
                - <<: *icon3
                - <<: *plot3
                - <<: *frame4
                - <<: *icon4
                - <<: *plot4
Debugging
The displays are very slow to update. As you set it up the way you want, you usually don't want to wait for the tag to update, or your turnaround will be slow. It's much quicker to set up a preview card with OpenEPaperLink's built-in camera entity, like this:
type: horizontal-stack
cards:
  - type: entities
    entities:
      - entity: sensor.0000021efa1e3411_battery
      - entity: sensor.0000021efa1e3411_last_seen
      - entity: sensor.0000021efa1e3411_rssi
    title: 02:1e:fa:1e:34:11
  - show_state: false
    show_name: false
    camera_view: auto
    type: picture-entity
    entity: camera.0000021efa1e3411_content
This works very nicely. Thank you! Would be nice if this blueprint could be expanded to support different sized display tags as well.
One bug I see is that a graph stops drawing when value is 0. I want to display a graph with solar power production. When the sun is down this is 0 but it will not continue the line till the end.
Any location in europe/netherlands where to buy these devices?
The Tindie store electronics by nic is in the Netherlands and writes that he will have stock again after February 9-ish.
Differently-sized tags in the same blueprint are a bit tricky, but I have a couple more blueprints in the works for larger displays.
Might be worth filing an issue against open_epaper_link_homeassistant.
Apparently the Tindie store is no longer making or selling anything.
Does anyone know of some other place where ready-made EpaperLink Access Points (AP) can be sourced?
Get into OpenEPaperLink there’s Discord Channel invite at the bottom - you can buy there anything you need - APs, tags from 1.54 to 13" size + support
@phrxmd can you please have a look at openepaperlink integration repo - v1.0 is going to be released soon (I know I know) and breaking change that prevents your blueprint from working:
  • Switched from entity-based to device-based automations
    I’m running 1.0.0.4_dev for over a week now and really with recent firmware websocket comms improved.
I’m a regular Discord user and there’s no organized way to buy anything on Discord. I’ve tried for a couple of weeks to to buy a ready made AP (Yellow) with a 3D printed housing, but so far no one I’ve found has anything to offer.
Any luck on the blueprint for a bigger screen
i have a 2,6" version and i would love to have it working true a blueprint
Many thnx
