I currently setup a new Raspberry with Home Assistant and try to display the date, when a sensor was updated. The value is available in the state object and I can use the following template to access it:
Hm ok, I hoped, that I don’t need to do this for all my sensors, but thanks for the idea!!
Let’s try it in another way:
On several screenshots I saw, that it seems to be possible to display the last update below the actual value (e.g. here: https://blog.openenergymonitor.org/images/ha1.jpg)
Has this been removed in newer versions or why is it not visible in my system (and many newer screenshots)?
That’s an excellent question. Even the screen shots on the front-end documentation show last updated.
I’ve never seen that implemented, maybe it’s something that went away?
